thermostat failure... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2004, 11:49 PM   #1 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
what are the common signs of a failed/failing thermostat?
Will the motor start to overheat?
Will I still get heat?
Edmond.
Edmond is offline   Reply With Quote
Old 11-12-2004, 11:53 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Failed thermostat..hmmm..
If stuck closed, you notice overheating...touch the radiator - it will be cold.
If stuck open, your car takes forever to warm up, when you drive, the temp falls and when you stop, it climbs.
old faithful
amerikim is offline   Reply With Quote
Old 11-12-2004, 11:58 PM   #3 (permalink)
Triple A Whore
Edmond's Avatar
Thanks for the quick response. I don't have either of those problems so I guess my thermostat is okay.
My heat doesn't work, it just blows cold air out. Any suggestions on where to look?
Edmond.
Old 11-13-2004, 12:13 AM   #4 (permalink)
amerikim's Avatar
Check your swiches especially if they are electric, switches at the firewall that allow hot water into the heat exchanger. Buya Haynes Manual at this part so you do not get lost.
Could also be crap stuck in there, so high pressure hose, blow it out.
old faithful
Old 11-13-2004, 12:32 AM   #5 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
A failed thermostat would cause your engine temp gauge in your instrument cluster to not work at all.
If it doesn't check all the fuses.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 11-13-2004, 01:13 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Wrong.
Theres a sensor for the temp guage. It has nothing to do with the thermostat.
"Skoolin' the unlearned!"
Old 11-13-2004, 01:26 AM   #7 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
Ok there is some confusion here. These guys are assuming you are asking about the thermostat in the motor. I would bet you are referring to the tempature control for your interior heater. Do a search on "Climate Control" that will get you the answers you are looking for. There is a thread about both the electronic and cable climate controls to your HVAC system that would more than likely help.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 11-13-2004, 10:25 AM   #8 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
check the radiator/heater core valve linkage. or you could manually open and close the passage from the radiator to the heater core from teh engine bay, locate at the firewall.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 11-13-2004, 02:06 PM   #9 (permalink)
userlain's Avatar
Originally posted by 88 LE
Wrong.
Snap.
Old 11-13-2004, 02:46 PM   #10 (permalink)
Triple A Whore
Edmond's Avatar
where is the heater core at and what does it look like?
Sorry but I'm Toyota stupid.
Edmond.
Old 11-13-2004, 05:14 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
^ The heater core is inside the car.
It looks like a little radiator.
This valve connects to it:
