Transmission Fluid - Kind of Blackish... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2004, 11:47 AM   #1 (permalink)
View jefe's Photo Gallery
1991 Toyota Camry 4-cyl, US built, auto, 220,000 miles.
Changed the transmission fluid yesterday and it was reddish/blackish in color. It was last changed about 1 year agowhen I replaced one of the axles.
Does this color indicate a definite probelm, a likely problem, or not necessarily anything to worry about???
THANKS!
jefe is offline   Reply With Quote
Old 11-13-2004, 12:08 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Sounds normalish to me..
All fluids break down with use.
Was it a full tran fluid flush or just a drain and replace?
Alot of the fluid remains in the tran if you just drain and top off.
One year later and all you get some coloring on a tran with 220K on it is pretty decent.
old faithful
amerikim is offline   Reply With Quote
Old 11-13-2004, 07:13 PM   #3 (permalink)
It was just a drain and refill. So I guess that's OK then? Thanks for the reply!
