alternator removal question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2004, 03:03 PM   #1 (permalink)
View thomas81z's Photo Gallery
HI everybody, i need a little help with my 1997 camry altenator today i was trying to remove the alt so i pulled out the bolt that hold the alt to the altenator bracket
after it was removed i still could NOT remove the alt ,there seems to be some type of sleeve that goes through the alt bracket hole and into the alt mounting hole so i cant take the alt all the way off any help thanks
thomas81z is offline   Reply With Quote
Old 11-14-2004, 03:36 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
it doesn't go in, it's an adjuster that slides. Just pry the alternator out if you have removed the 2 bolts that secure it.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 11-14-2004, 10:12 PM   #3 (permalink)
SiennaSC98's Avatar
View SiennaSC98's Photo Gallery
If your alternator looks like this (98 Sienna): Altenator
Try this way:
After your removed the alternator bolt and the adjuster (belt tension) bolt, turn the alternator sleeve (hex head) to lossen alternator from the engine (mount) bracket.
SiennaSC98 is offline   Reply With Quote
Old 11-14-2004, 11:28 PM   #4 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
just use a rubber malet, it will come right off
Porkch0p220 is offline   Reply With Quote
