amp question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2002, 05:26 PM   #1 (permalink)
View bigcarlos59's Photo Gallery
i have 2 mtx 12' 6000 subs 250 rms each. i have a mtx 250d amp the thing keeps thermal shutin off on me any whay around this?
bigcarlos59 is offline   Reply With Quote
Old 06-19-2002, 06:45 PM   #2 (permalink)
View tmanana's Photo Gallery
Well....if they are the duel 4ohm voice coil version....you might have the coils and speakers wired in parallel, which would present a 1ohm load, thus easily putting that MTX into protection load. If the coils are wired in series, and speakers in parallel, they would present a 4 ohm load, which is much easier on the amp, but the power draw will be much less.
Ok....I just looked up the stats on the amp:
RMS Power measured at 12.5 Volts DC:
-125 Watts x 1 into a 4Ohm load with less than 0.5% Thd+N
-250 Watts x 1 into a 2 Ohm load with less than 1% Thd+N
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC
-200 Watts x 1 into a 4 Ohm load
-350 Watts x 1 into a 2 Ohm load
Lets say your electrical system is stock...so maybe pulling a 13-something volt level....so pushing out between 125 and 200 watts at any given time....basically that amp is underpowering those subs extremely bad. RMS for those subs are 250....thus lies the problem. :sad:
I know MTX says they underestimate the power of their amps....but that bit of difference is pritty major. General rule of law is that one should buy an amp that covers a sub's max wattages.
_________________
2002 National Sound Pressure League Record Holder...so the road doesn't really vibrate that much?
Hey look! Girls like my car, so they MUST like me..oh wait :sad:
<font size=-1>[ This Message was edited by: tmanana on 2002-06-19 19:47 ]</font>
tmanana is offline   Reply With Quote
Old 06-20-2002, 01:01 AM   #3 (permalink)
ok help me out i am thinking of up grading the subs to the 8000 12's and was going to run the apline componets and type r 6x9's
what mtx amp do i need to do this i want to keep mtx amps and subs in my car also my head lights dim bad when the bass hits. what kind a cap should i get? i like the looks of a digital cap oh by the way i am new to car audio!!! :sad: so what all is needed to get some good sound out of this combo and what kinda box is the best
thanks for all the help
JIM
Old 06-20-2002, 10:04 AM   #4 (permalink)
Well.....if you are going to make that upgrade....and you want to stick with MTX amps...I say Thunder81000D all the way. They are mean amps, but you are looking to pay 600.00 to 700.00 for it :razz: But from what I have been told, they are awsome performers. If you are not looking to make that investment, I say stick with the subs you have and maybe move up to a Thunder6500D. I would say that would be sufficient. When it comes to caps....they are a quick fix. I run one and it helps with the dimming...but you do loose a small bit of power going to the amp due to the fact they cap is taking a draw to recharge. I say if you are really concerned about your power:
1) get a 1 farad cap
2) make sure you are using correct gauge power wires
3) increase your grounds from the battery to the body
4) drop in a deep-cycle battery like an optima
Well I know that was a lot....sorry I tend to be long-winded :razz:
-Toby
2002 National Sound Pressure League Record Holder....Hearing is Overrated
Old 06-21-2002, 05:09 PM   #5 (permalink)
what mtx amp will i need to run my alpine comps and the 6x9?
