starter no start.... ignition faulty??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2004, 04:40 PM   #1 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
this morning came out and tried to start my 5sfe but starter doesnt do anything. i had to manually jump the starter wire to the batt to start.
my question:
maybe perhaps i blew a fuse?
is there a fuse for this?
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 11-16-2004, 12:31 AM   #2 (permalink)
anyone?
Old 11-16-2004, 03:10 AM   #3 (permalink)
View karazy's Photo Gallery
Of course there is, several actually. There are a few safety switches too. Depends on what you're driving.
karazy is offline   Reply With Quote
Old 11-16-2004, 10:16 AM   #4 (permalink)
i thot were in camry forum..... my sig says 5sfe 4cyl, doesnt it?
Old 11-16-2004, 11:10 AM   #5 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
Well, first of all, did the starter turn over at all?
If so, could you hear it at least attemping to fire?
If the starter is working but it does not fire, your timing may be off. It may also be a damaged spark plug or any nymber of other causes.
You can also check the fuses. If it's a Gen3, there should be a little change holder on the driver side near the door. If you push in on both sides you can remove it and expose the fuse behind it.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 11-16-2004, 11:27 AM   #6 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
If you had a metallic clink only, Possible start of bad starter.
If it was click..click..click.. battery ??
could you give more info on the "jumpered wire"??
CraigW is offline   Reply With Quote
Old 11-17-2004, 09:10 PM   #7 (permalink)
if yall ever look at th starter, there are two wires goin to the starter. one(4 guage) is for the 12volt constant, the other(10 guage) is for switching (ignition key, +12v).
i jumped the 10guage wire to the batt and my car start.
my ignition does send any power to the 10 guage wire at thstarter.
thats why i ask is there were any fuse for it sicne i couldnt find it. some one mentioned the switch, could it be the neutral switch?
thanks
Old 11-18-2004, 02:29 AM   #8 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
take it to autozone. they do free battery and starter diagnostic.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 11-18-2004, 03:58 PM   #9 (permalink)
thanks for everyones help.
ill take a look at it this weekend, will see whats up.
Old 11-19-2004, 08:00 PM   #10 (permalink)
Pearl Jam-5150's Avatar
Gameroom cash: $313100
View Pearl Jam-5150's Photo Gallery
- Park/Neutral Position Switch (Car Will Only Start In Park Or Neutral)
Or
- Clutch Start Switch (Car Will Only Start With Clutch Pedal Pressed)
Maybe A Bad Switch? Or In Need Of Adjustment?
Hope This Helps,
Ed
Pearl Jam-5150 is online now   Reply With Quote
