Originally posted by cam98hi
thanks, after i finish the circuit board, you have any idea how I can put it in
I look over the wiring diagram and from the look of it the headliner would have to be removed. Because the control device switches both the hot 12v and the ground. If they haven't changed the way they make cars the ground would be grounded right at the dome light. So there would be nothing to tap into going up the door post.
It is possible that you could use the exsisting hot lead to pull 2 new wires in and ground the dome light remotely.
