light bulb warning?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2004, 07:06 PM   #1 (permalink)
View polska2084's Photo Gallery
on a 96 camry my sensor that i have a light out somewhere is on. but there i cant find any bulbs that are out. is there a way to get that light off on the dash..thanks
polska2084 is offline   Reply With Quote
Old 11-16-2004, 07:21 PM   #2 (permalink)
5sp 3VZ-FE
mescalito's Avatar
View mescalito's Photo Gallery
Usually its because there IS a bulb out. Try replacing the 3rd brake light bulb even if it still works, sometimes thats the issue.
mescalito is offline   Reply With Quote
Old 11-16-2004, 07:23 PM   #3 (permalink)
thanks but i prety much cheked every bulb in the car im so confused and its annoying is there a way to get ride of the warning.. and yes it did start when the 3rd brake lite was out it goes on when i press the brakes??
Old 11-16-2004, 09:51 PM   #4 (permalink)
5sp 3VZ-FE
mescalito's Avatar
Well, I'm just going by experience...
I too had the annoying light on and checked/replaced every bulb on the outside including the liscense plate lights - with no luck. So I changed the 3rd brake bulb even though it still worked and that corrected the problem. Sounds like you have the same symptoms, but only you can know for sure.
The light will not go out untill the problem is remedied, or you remove the actual light from the dash - I would reccomend that as a last resort.
Old 11-17-2004, 12:49 AM   #5 (permalink)
Gameroom cash: $927300
iTrader Score: 13 reviews
View ASG14's Photo Gallery
If the check light, light goes on ONLY after you press the brake, it is a BRAKE light out. And I had it go on once when I could not find an out bulb, turns out it was the 3rd brake light only intermittently going out.
5 Lug Corolla WHAT?
Old 11-17-2004, 06:31 AM   #6 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Did you use a conventional bulb or an LED replacement for that bulb ?
CraigW is offline   Reply With Quote
Old 11-17-2004, 06:35 AM   #7 (permalink)
im using reulat dot bulbs and yes i did replace the 3rd brake light.. this is soo annoying is there some type of sensor on the 3rf brake light that can be not conected or i dont know. thanks
Old 11-17-2004, 04:09 PM   #8 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Sometimes that warning will go on before a light is blown, like a pre-warning. Give it some time and see if a bulb blows. If now, then it's gotta be an error with the sensor. I can't see why it would stay on if all the bulbs a fine.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-17-2004, 04:18 PM   #9 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Could be a loose filimant in one of the bulbs or your license plate bulbs
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 11-17-2004, 04:59 PM   #10 (permalink)
Gameroom cash: $304355
Make sure the bulb you replaced was the right one; not just a bulb that fit the socket. The sensor senses wattage, not voltage, so if you use another bulb with a different wattage the sensor will go on every time you step on the brakes. The correct bulb for your 96 Camry high mounted brake light is a 921. Also check all the brake light sockets themselves. Sometimes the contacts can get corroded or bent. The last thing to check is the harness in the trunk near the hinge on the driver's side. This area is notorious for having a broken wire inside this loom caused by all the bending when opening and closing the trunk.
Mike
Old 11-17-2004, 05:17 PM   #11 (permalink)
The Camburger
iTrader Score: 6 reviews
View Admiral's Photo Gallery
the back side parking lights are are really hard to notice. u check them to? if all else fails take out the dash and remove that warning bulb.
Admiral is offline   Reply With Quote
Old 11-17-2004, 06:40 PM   #12 (permalink)
VeeZed
Another example of a bandaid fix it!!
Old 11-17-2004, 08:56 PM   #13 (permalink)
maybe it is the broken harness or the diff wattage thanks
