Drl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2004, 12:14 PM   #1 (permalink)
View 99CamV6's Photo Gallery
Drl
How to disconnect the DRL? If this kind of threads have been posted before, let me know.
99CamV6 is offline   Reply With Quote
Old 11-17-2004, 03:24 PM   #2 (permalink)
The Greatest
View CamNub's Photo Gallery
It has. You have to do something w/ the fuse box and disconnect it.
CamNub is offline   Reply With Quote
Old 11-17-2004, 09:31 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
To turn off your DRL's -- you'll want to unplug the DRL resistor pack in the engine bay, located in the corner near the passenger side firewall. If you look in that corner about a foot down or so, there's a metal box roughly the size of a pack of gum, maybe a little bigger. It sits on a metal bracket and is attached at a 45 degree angle to the corner. It'll probably have some kind of "don't touch" label on it since it gets pretty hot under use. If you know where your engine diagnostics connector is, it's roughly in the same corner except closer to the firewall and further down. Unsnap the two connectors and there it goes.
The sensor on the dash controls the "auto low-beam" feature (twilight sentinel). To unplug the dash sensor, pop off the top with a small screwdriver, unplug the sensor, and put the cover back on. You should use a zip tie or a piece of string to tie the sensor to the cap so it won't fall into the dash. That way you can re-enable it in the future if you choose to do so
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-18-2004, 06:44 PM   #4 (permalink)
Thank you guys! I did it!
Old 11-20-2004, 02:45 AM   #5 (permalink)
View fox_prime's Photo Gallery
csaxon
i've been trying to disable the DRLs too. i was able to unplug the sensor on the dash, but i couldn't locate the metal bracket near the in the engine bay.
i've looked near the engine diagnostics connecter (labeled as "diagnosis" on the small black match-looking box) for quite a while.
do i have to remove anything just to find the DRL resistor pack? what does the passenger side firewall look like...is it the wall below the strut tower brace (if any) on the passenger side?...or is it the black foam-looking wall below the windshield wipers? thanks a lot.
fox_prime is offline   Reply With Quote
