Oil leak nightmare - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2004, 06:07 PM   #1 (permalink)
View dwhealon's Photo Gallery
Oil leak nightmare
Hey, my 91 V6 has developed an oil leak that I just can't find!!!
Power steering pump is wet and dripping off two or three places. Its also running down the back of the block and pan. It really looks land feels ike engine oil. I had the power steering pump off and rebuilt it and replaced all the seals. (Didn't change the leak at all) Installed new Toyota valve cover gaskets. It leaks about a 3 inch spot every night.
Any ideas other than head gasket would be greatly appreciated.
dwhealon is offline   Reply With Quote
Old 11-18-2004, 06:17 PM   #2 (permalink)
cam2Xrunner's Avatar
Oil sending unit maybe?
Old 11-18-2004, 06:22 PM   #3 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Did you add or change in some synthetic oil? The detergents in the synthetic could have cleaned out the grime that is holding back a leak.
Maybe an intake manifold gasket? Maybe Valve cover gasket?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 11-18-2004, 07:24 PM   #4 (permalink)
I just went out there and crawled under it again, dried everything off and ran it a while. Its definitely above the power steering pump on that side of the motor. I haven't run synthetic at all. The sending unit is on the front and that's dry. The valve cover gaskets are new and look dry all the way around. Are there oil passages in the intake manifold? It doesn't seem like there would be.
Could it be that back cam seal? Has anybody had one of these go bad? Maybe leaking inside the timing belt cover and out the bottom of it, which is above the power steering pump.
I gotta fix this before the snow flies.
Thanks for your help.
Old 11-18-2004, 07:49 PM   #5 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Head gasket? There are no oil passages in the intake manifold. On the passenger side of the engine, PWR steering pump side, there are only a few places it could leak from. The headgasket, the valve cover, and the oil seals on the shafts which are by the steering pump. Try some ultraviolent dye testing kits. You shouldn't have too much trouble finding where the oil comes from if you move some stuff out of the way...
97camryman is offline   Reply With Quote
Old 11-18-2004, 08:09 PM   #6 (permalink)
Unhappy
Yeah, I gotta move some stuff. I put a timing belt in it last year and I really hate going in that side of the motor! Looks like its gotta be done, though.
I wish you wouldn't have said headgasket.
Old 11-18-2004, 08:11 PM   #7 (permalink)
Its freakin hot here...
View ArmyofOne's Photo Gallery
headgaskets do nt typically leak oil out, but rather coolant in. i would lean towards the Oil Pump Seal (sending unit seal). mine leaks from there, about a full quart a month.
2006 Honda Civic EX in Galaxy Gray Metallic Pearl-WR Blue Brake Calipers, Ipod Integration, Debadged, K&N Drop-In, Mobil 1 Synthetic oil, Bridgestone Turanza 215-55-R16 Shoes, RedStuff Ceramic Brake Pads, Tint w/3m SolarGaurd film: 5% rear, 15% front, 30% moonroof
ArmyofOne is offline   Reply With Quote
Old 11-18-2004, 10:04 PM   #8 (permalink)
userlain's Avatar
Are you sure it is oil and not coolant or petrol?
Old 11-18-2004, 10:07 PM   #9 (permalink)
look at your coolant, if its not brown/grey with the consistency of thick mud, you dont have a blown headgasket
Old 11-19-2004, 07:01 AM   #10 (permalink)
Its definitely oil. Coolant is green and clear and it hasn't gone down at all. I thinik I'll tear the right side of the motor apart tonight and get a look at the cam seal.
I'll keep you posted.
