Originally posted by stanleyeye
I am not sure how to keep the crankshaft 100% fixed when we loose the crankshaft pulley bolt. Can anyone give me some advice?
Wedge the flywheel/flexplate with a crowbar.
Theres a access plate on the bottom left side of the tranny that you can remove.
Access plate
Flywheel/flexplate
Instructions for timing belt
http://yotarepair.com/5S-FEtimingbelt.html
http://yotarepair.com/1FZ-ME_timingbelt.html
Originally posted by userlain Make a vertical mark to match it back up to when you reinstall the belt.
Thats only if your going to reinstall the same belt.
But even then you don't need to make any marks.
Theres alignment marks on the cam gear(s) and crank pulley.
