rattling problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2004, 10:41 PM   #1 (permalink)
Solorange's Avatar
View Solorange's Photo Gallery
rattling problem
On the front passenger side of my car i hear a noise like something is loose when ever I go over a medium or large bump. I think it may be the suspension. Im not sure whether something is loose, something is broke, or if its a normal noise. Its kindof hard to tell though. Everything looks fine and the car drives fine but that noise has been getting to me. Any suggestions or is this just a normal noise? Thanks Chris
99 Toyota Solara SE V6 5spd
09 Toyota Highlander Sport
05 Jeep Wrangler Rubicon
http://www.cardomain.com/ride/2086758
Solorange is offline   Reply With Quote
Old 11-18-2004, 11:01 PM   #2 (permalink)
View Calvin327's Photo Gallery
What kind of noise are we talking about here? Clicking noise, clunking? If its coming from near the strut area, it could be the strut itself, bad spring, axle or just a torn insulator (the rubber)
Check those things out,
Calvin
Calvin327 is offline   Reply With Quote
Old 11-19-2004, 06:22 PM   #3 (permalink)
Solorange's Avatar
I dont think it would be a strut. Im thinking the spring is it. but it sounds like a clunk noise.
Old 11-19-2004, 07:08 PM   #4 (permalink)
View Fever's Photo Gallery
Strut mounts maybe.
'97 Camry XLE
Fever is offline   Reply With Quote
Old 11-19-2004, 11:15 PM   #5 (permalink)
The Greatest
View CamNub's Photo Gallery
I thought I wrote this before. But i believe you need your timing belt replaced. I'd say that is the most likely cause of the noise. It sounds like something is loose right?
CamNub is offline   Reply With Quote
Old 11-22-2004, 05:37 PM   #6 (permalink)
Solorange's Avatar
Yeah, but the timing chain looks brand new, and i only happens when i hit bumps.
Old 05-06-2006, 12:17 PM   #7 (permalink)
View blueapple's Photo Gallery
Most likely the strut mount, and they usually go from the RH side first, ( heaver load from the engine maybe? ) All old camrys I've seen, including mine had more or less of it.
Well, some times a good torque ( 49lb ft or so, don't go too crazy ) will fix it, this is in my case. But some times it requires replacing the strut mounts. While at it, just do both. ( it's 100 dollars each from dealer and maybe 50 from KYB, parts alone).
blueapple is offline   Reply With Quote
