Exhaust advice needed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2004, 04:15 PM   #1 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Unhappy Exhaust advice needed
Here is my current setup: pacesetter header, 1.75" pipe to the stock resonator, resonator, 1.75" pipe half way to my muffler, 2.25" pipe the rest of the way to my muffler, straight through N1 style muffler.
I think that the pipe should be a uniform 2.25" pipe. I called the only local muffler shop that I trust and the guy said he couldn't work all the way up to the header because it is state law that I have a cat converter, which I don't because it, and the manifold, were replaced with the pacesetter exhaust header.
This is what I would like to have done: 2.25" from header back to resonator, 2.25" resonator, 2.25" pipe back to muffler, Ractive M-252 Oval muffler
I told the guy at the muffler shop that this is what I wanted done, and he said that I would be loosing quite a bit of backpressure and almost all of my low-end.
Any input would be much appreciated.
EDIT: MY STATE DOES NOT REQUIRE EMISSIONS TESTS
EDIT 2: I AM TRYING TO ACHIEVE A DEEP, BUT NOT LOUD OR FARTY, TONE AND TO KEEP THE PIPE DIAMETER UNIFORM
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 11-19-2004, 04:17 PM   #2 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
he right but you would gain this up in the top end and mid range ... just add a 2.25" hi-flow cat to get a bit of back pressure ... You could also run a louvered exhaust instead of perfolated one...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 11-19-2004, 04:23 PM   #3 (permalink)
userlain's Avatar
Can you quickly explain the terms louvered and perfolated? Thanks bro!
Old 11-19-2004, 04:32 PM   #4 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
You can get a 2.25" in/out performance cat from Random Technology. I got a 3" in/out from them for my TE72 Corolla.
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 11-19-2004, 04:33 PM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
louvered means if you look into the muffler it has these little bumps with holes facing the exit of the muffler... These are there to create back pressure. Old school design
perfolated means if you look into the muffler it has no bumps just a bunch of holes in there. Thats perfolated these are for more high flow and turbo setups... More modern design as well because they match the exhaust piping with the exhaust flow of the motor.
MySpace:
Old 11-19-2004, 04:50 PM   #6 (permalink)
userlain's Avatar
Thank you!
So do you think all of my bottom end will be gone? Or was the guy exaggerating?
Old 11-19-2004, 05:45 PM   #7 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
Thank you!
you'll lose some of the bottom end but not all of it
MySpace:
Old 11-19-2004, 06:01 PM   #8 (permalink)
View wujo's Photo Gallery
quick question about exhausts when we are on this topic. i had a big gash in my exhaust pipe from the resonator to the muffler, and i had to get it replaced. a buddy of mine told me that i should get the resonator removed because it will add some hps. is this true?
i went and got an aftermarket muffler and went with a 2.5 pipe from the cat all the way back. without the resonator did it add hps? because i am thinking about throwing back on the resonator, since it is really loud now. it's deep and doesn't sound like a crappy exhaust system, but just loud.
wujo is offline   Reply With Quote
Old 11-19-2004, 06:02 PM   #9 (permalink)
userlain's Avatar
What car do you own?
Old 11-19-2004, 06:34 PM   #10 (permalink)
03 camry SE
Old 11-19-2004, 06:38 PM   #11 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
its add horsepower but its mostly higher rpm spectrum... As for your resonator, the resonator is just like having another muffler. so just make sure the resonator is also 2.5" in and out ... Then it shouldnt restrict flow ...
MySpace:
Old 11-19-2004, 09:56 PM   #12 (permalink)
View 562camry's Photo Gallery
go straight pipe
http://members.cardomain.com/562camry
562camry is offline   Reply With Quote
Old 11-20-2004, 12:39 AM   #13 (permalink)
userlain's Avatar
Originally posted by 562camry
go straight pipe
DO you have any idea how loud and obnoxious that would be? It would be like an atom bomb!
I may need to add that I want a deep, but not loud, and sexy tone.
Old 11-20-2004, 09:06 AM   #14 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
If you ever come to bethel, dont drive threw with that. they will pick u up in a mater of seconds
Porkch0p220 is offline   Reply With Quote
