Dash Ground location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2004, 09:26 AM   #1 (permalink)
View amanaland's Photo Gallery
USA Dash Ground location
I bought a '92 Camry 4-cylinder to polish up and notice that the temperature guage isn't working. Then I see that the fuel guage is sluggish and I am getting poor reception on the factory radio. I'm thinking that it could be something as a bad ground. Does anyone know where that is located?
amanaland is offline   Reply With Quote
Old 11-20-2004, 10:41 AM   #2 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
I've got a '95, when I was installing my neon under the dash, I grounded to one of the screws that was near the fuse box behind that little change pocket thing. If you need to find a ground, use a voltage tester and see where you can get the most consistent (sp?) voltage flow. I'm pretty sure the gauge and radio are on different grounds.
BTW One time my radio lost reception, the antenna connector had fell off
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
