what should I replace when I replace timing belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2004, 12:15 PM   #1 (permalink)
View stanleyeye's Photo Gallery
water pump, oil pump, tension spring....
Anyone can give me some advice?
Many thanks
stanleyeye is offline   Reply With Quote
Old 11-20-2004, 12:40 PM   #2 (permalink)
幻影
Phatfantom68's Avatar
View Phatfantom68's Photo Gallery
The timing belt should be replaced every ~60,000 miles. As for the rest, check your manual, because it might have the answers.
1991 Lexus LS400 (UCF10)
1991 Toyota Camry DX (SV21)
1984 Toyota Celica GT (RA64)
1994 Ford F250 XLT
Phatfantom68 is offline   Reply With Quote
Old 11-20-2004, 01:32 PM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
when you replace the timing belt you might as well do the water pump too. oil pump rarely goes bad in toyotas.... last time my water pump went bad i replaced the timing belt as well since you/mech is going to be in that area already
Old 11-20-2004, 04:15 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Timing belt, 2 accessory belts, water pump, and the tensioner spring.
Check the idler/tensioner pulleys and replace if their bad.
Check the front main seal and cam seal(s) for any sign of leakage.
"Skoolin' the unlearned!"
Old 11-20-2004, 09:02 PM   #5 (permalink)
View Kaliman's Photo Gallery
Timing belt
Tensioner and guide bearings
Camshaft gasket
Crankshaft gasket
Other gaskets in front of engine (Gaskets r pretty cheap)
Water pump
Valve cover gasket in case of taking off.
Oil cap gasket.
Tips:
Clean engine's front with carburator cleaner after removing belt and bearings, and before removing old gaskets.
Then remove old gaskets, clean shaft's surfaces and use grease to fit brand new ones. (Only grease the inner side of the gaskets a little bit)
Good luck!
Kaliman is offline   Reply With Quote
