Originally posted by djxlilman
Is it hard to replace it? Do i have to remove the whole throttle body to replace it?
Yes, you need to remove the TB (throttle body) to replace the IAC.
The IAC is held onto the bottom of the TB with a few screws.
Theres also a gasket that you need to replace. It goes in between the IAC and TB.
Check the ECT (engine coolant temp) sensor. This is another cause of the cold start low idle problem.
The ECT is on neck that bolts onto the right side of the cylinder head.
