Camry bottomed out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2004, 06:53 PM   #1 (permalink)
asscarracer's Avatar
View asscarracer's Photo Gallery
Camry bottomed out
My 1993 Camry LE I4 bottomed out on Friday when I was going over some speed bumps at school. I go over them everyday and this has never happened, I did have 3 other people in the car. I was wondering if this means my shocks are going bad. If the shocks are bad, what is a good moderately priced set to buy.
1993 Camry LE w/ 104xxx mi
Python Remote Start/Entry, Low-Beam Silverstars, Ceramic Pads, Double Tipped Platinum Plugs
asscarracer is offline   Reply With Quote
Old 11-21-2004, 07:07 PM   #2 (permalink)
S14 Fever :D
Rapeacivic's Avatar
View Rapeacivic's Photo Gallery
Yeah, your rear shocks are probably bad
Originally Posted by LynchburgCSI View Post
Ladies and gentlemen... the only turbo 5s-fe camry still in existence. Welcome back Terry. I can't wait to see how this goes.
Rapeacivic is offline   Reply With Quote
Old 11-21-2004, 07:09 PM   #3 (permalink)
TN's Resident Goddess.
Lauren's Avatar
Gameroom cash: $550322
View Lauren's Photo Gallery
I think you just went over it a bit fast and with the weight. My struts are new and last night I bottomed out on a speed bump with people in the back of my '95. Check out if you have odd sounds and read...
Camry struts
I am the kind of woman that when
my feet hit the floor each
morning the Devil says,
"Oh shit, She's Up!"
http://www.cardomain.com/ride/3389758
Lauren is offline   Reply With Quote
Old 11-21-2004, 07:12 PM   #4 (permalink)
S14 Fever :D
Rapeacivic's Avatar
Well, when people sit in the back seat does your car lower like 2-3 inches?
Old 11-21-2004, 07:14 PM   #5 (permalink)
Lauren's Avatar
Mine does. Plus going fast over a bump doesn't help. Usually I dont cart people around in my car. That's the 'rollas job!
Old 11-21-2004, 07:20 PM   #6 (permalink)
On The Street
View famous182's Photo Gallery
ya my shit hits too. but some speed bumps here are huge, so it hits, but i go fast over those things and sometimes i go slow and it doesnt hit
97 Toyota Camry
Live Fast Die Young
famous182 is offline   Reply With Quote
Old 11-21-2004, 08:00 PM   #7 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Don't know if you have tried it but try going over the bump at an angle.
It works for me.
amerikim is offline   Reply With Quote
Old 11-21-2004, 09:14 PM   #8 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
^ what he said....
that and you don't realize how low the camry actually sits...the actual frame sits a lot lower than the parts of the body that you can actually see...
HaHa
Old 11-21-2004, 10:23 PM   #9 (permalink)
Lauren's Avatar
Originally Posted by Eye8Pussies
^ what he said....
Yeah it is low. I'm pretty thin and I have to jack up the car a bit to fit under and drain my oil...plus if you got the black trim on the bottom, it also hides the lowness of the car.
Old 11-21-2004, 10:29 PM   #10 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
I bottomed out on the highway and now have a 9 inch hole in my chasis. lol
Edit: 9 inches long and about 2 inches wide.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 11-22-2004, 07:07 PM   #11 (permalink)
so is this normal for a camry under 250 lbs of weight in the back and 250 in the front, or do you think I should get some new shocks (I have no idea what are good and what are bad, so I might need some sugguestions).
Thanks,
John
Old 11-22-2004, 07:13 PM   #12 (permalink)
The Other White Meat
terrastrife's Avatar
its probably normal, if you had more load on the car then usual youd probably bottom out if you were going the same speed as you usually do with less ppl.
terrastrife is offline   Reply With Quote
Old 11-22-2004, 07:41 PM   #13 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
I dont believe there is a camry out there that doesnt bottom out over something like that... i always freak out when i go off a street into a driveway sorta fast.
MadDawg is offline   Reply With Quote
Old 11-22-2004, 08:48 PM   #14 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308575
Unless your car handles poorly, you probably don't need new struts. Compression of the springs (and their rate) is what's responsible for bottoming out, not the struts...
Oh yeah... try lowering your Camry 2" or so and then go over those same speed bumps - its a real challenge. My camry has frame and crossmember parts that are only 3-4" off the ground.
-Charlie
