Sorry guys more supercharger questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2004, 12:51 PM   #1 (permalink)
View UK_MRV6's Photo Gallery
UK Sorry guys more supercharger questions
Hi guys, i'm in the process of buying a supercharger for my 1mz-fe. The problem is it's off a Toyota Sienna, is it straight forward to convert the supercharger for a manual transmission as the sienna supercharger only comes in auto form.
Phil.
UK_MRV6 is offline   Reply With Quote
Old 11-23-2004, 02:22 PM   #2 (permalink)
View I4 to V6 Swap's Photo Gallery
I bought the manual supercharger for my camry, and the boost control computer came with it. I was puzzled. I just didn't install the boost control. You should be fine not installing the boost control. I could be wrong though.
I4 to V6 Swap is offline   Reply With Quote
Old 11-23-2004, 02:25 PM   #3 (permalink)
14.3@96mph
View thakidd's Photo Gallery
i belive the egr tubes are differnt on a manual.....plus u will need a few other parts to get the s/c to work on the camry...
"Happieness Is Being Blown"
thakidd is offline   Reply With Quote
Old 11-23-2004, 02:32 PM   #4 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
he has an mr2 with a 1mz in it, not a camry.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 11-23-2004, 02:38 PM   #5 (permalink)
Hi guys, the sienna supercharger part no. is 00602-17620-305. The camry's is 00602-17620-304, so I would say there are both the same chargers only the part nos. are different so you can identify the model it's for. However I've been told that all you need is
Supercharger belt 00602-17620-330
Assembly, Idler plate and Pulley 00646-17620-320
Convoluted EGR tube - Auto 00602-17620-360
and this should be ok to run the supercharger on the 1mz-fe set up. Would just like someone to confirm this to me before I go ahead and buy it.
Old 11-23-2004, 05:25 PM   #6 (permalink)
限界域への独走。
View mobes's Photo Gallery
What year is your 1MZ from? If it's a 94-96, you'll need to make your EGR tube custom, since they changed the EGR setup in 97.
mobes is offline   Reply With Quote
Old 11-23-2004, 05:36 PM   #7 (permalink)
Hi mobes, it's from a year 2000 camry.
Old 11-23-2004, 06:03 PM   #8 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
UK_MRV6, the fact that you've transplanted the 1MZ into your MR2, your engine is no longer oriented either as a Camry or a Sienna. However, I will confirm that the only difference between the manual and auto kits for the Camry is the EGR pipe and how the EBC is wired up (if at all). There's a site which documents what's involved in this very project. I can't find it right now. Once the search feature is up and running again, I'll PM you the info.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 11-23-2004, 06:12 PM   #9 (permalink)
Fair coment, the car is abit of an oddball and I know that various sites have relevant info regarding the swap. However i have by far received more help and response from you guys on Toyota Nation than on any other forum. And it's much appreciated!!
Phil.
Old 11-23-2004, 06:28 PM   #10 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
We'll do what we can to help bring your dream of and SC'd V6 Mr2 to life
Old 11-23-2004, 07:07 PM   #11 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
yeah, what mobes said... the EGR tube is the only difference. i actually looked at that sienna auction on ebay right now... it should work, you will probably just have to cut the EGR pipe that you have now and alter it slightly. it should be easy enough to do. for a master such as yourself... if you can put a 1mz in an mrdeuce, you should be able to do this with no problems. good luck with it. I am most certainly going to come to england for a ride in this bad boy once its all set to go
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 11-24-2004, 04:51 AM   #12 (permalink)
Thanks guys I am going to go ahead with the purchase. I can't take the credit for the engine conversion as I didn't do it myself. The guys that did it won't have any problems at all with the supercharger. It was originally planned to put a 3s-gte engine in but a friend of mine pointed me in the direction of some guys in america that had put the 1mz-fe engine in. As soon as I saw and read the info I knew this was the only swap to do.
http://www.imoc.co.uk/users/upload/MrV6-1.doc
Old 11-24-2004, 06:55 AM   #13 (permalink)
The Other White Meat
terrastrife's Avatar
that strut brace may get in the way...
terrastrife is offline   Reply With Quote
Old 11-24-2004, 09:00 AM   #14 (permalink)
Yeah I think your'e rightl, but the guys who did the conversion will be able to make me a new one.
Old 11-24-2004, 01:03 PM   #15 (permalink)
I'm a Mac
zoni's Avatar
word is... when there is a s/c, one of the engine mounts must be removed... i read that on one of the mr2 1mz s/c pages... i really wish www.mr2oc was up right now i could show you...
http://www.atlantamr2s.com/owners%20...20vick/MR2.htm
Dave Zoni
