I Have 4 Cylinder CAMRY 1996 And I Want To Replace The Air Filter. But I Found One Wire Just Behind The Box Of the Air Filter.
Does Any One Know What Is It ? And Where I Connect It With The New cold Intake filter.
Another Question
Will The Car Consume More Fuel If I Install It? I mean more air inside the engine.
could you be more specific? a wire? not a tube of some sort? where does it lead to? try not to touch any of the electronics. if you are replacing the whole box with a pod or something similar, the most youll see is maybe a slightly better consumption, and a nice throaty intake noise.
Could it be the intake air temp sensor?
I installed a POD filter on a 96 Paseo and it had one of these. Looks like a sensor when you remove it. I just put it into the intake tube. Works fine.
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
if you're referring to the air sensor on the back out side of the air box... leave it there!!
if you're talking about replacing the air filter... just undo the 2 or 4 latches around the air box, lift it up, pull out the old filter, and put the new one in there... and re latch it all... very simple
