fan will not turn off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2004, 04:17 PM   #1 (permalink)
View watkinsfl's Photo Gallery
I have 90 camry 4cl, auto trans,. dual cooling fans, I shut off engine and both fans run even after engine has cooled. Started car again and same problem remains. Think it's the relay but I'm not sure where the relay is located. Any help?
watkinsfl is offline   Reply With Quote
Old 11-26-2004, 05:25 PM   #2 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
The fans remain on until the engine is cool.
If I understand correctly, the fans stay on for prolonged periods of time? Have you checked your engine temp on your dash when you turn off your car? Your engine may just be getting really really hot.
It could be a thermostat problem.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 11-26-2004, 05:39 PM   #3 (permalink)
fans remain on
Changed out thermostat several weeks ago. Car was running hot until the change out. Ran great for several weeks. Fans remain on even after engine is cold to the touch.
Old 11-26-2004, 05:41 PM   #4 (permalink)
fans remain on part two
had to disconnect neg bat cable to get the fans to turn off.
Old 11-26-2004, 05:58 PM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Ive got the same problem with my AC cooling fan. My primary thermo shuts off and turns on with the engine temprature though. Could it be in the AC fan relay?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-26-2004, 06:03 PM   #6 (permalink)
fans run after car is off
Don't know. Could be but I'm thinking it's an actual fan relay. You could be right.
Old 11-26-2004, 07:06 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Look in the fuse box in the engine bay. The fusebox is on the right side of the engine bay, behind the battery.
Theres 3 relays for the fans. A/C fan relay no. 3, A/C fan relay no. 2, and RDI (radiator) fan relay no. 1.
"Skoolin' the unlearned!"
Old 11-26-2004, 07:22 PM   #8 (permalink)
re: fans will not turn off
Thanks 88LE. I don't have RD1 listed but it does say "FAN NO. 1" That's it? Can it be bought at a parts store, (ie. NAPA, Advance) or does it have to be a toyota part? Thanks!
Old 11-26-2004, 07:32 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Yup.
I'm not sure. It might be a Toyota only part.
Theres a way to test relays. I'll have to look at mine and see if I can figure it out.
Old 11-26-2004, 07:51 PM   #10 (permalink)
RE: Fan runs
Thanks dude. I pulled it and the fans turned off. Don't have my multimeter with me but will have it checked tomorrow. It is a Toyota part but I wonder if it can be cross-referenced?
Old 11-26-2004, 08:12 PM   #11 (permalink)
RE: Fan runs cont.
Got it. Tested the relay and side from fuse to motor is stuck closed. Thanks for your help!!
Old 11-26-2004, 08:18 PM   #12 (permalink)
Speed Racer
toyotachick's Avatar
View toyotachick's Photo Gallery
good to help....lol..I would have say that it was the thermostat.
I would rather be hated for someone I am, then to be loved for someone I am not.
toyotachick is offline   Reply With Quote
Old 11-26-2004, 08:22 PM   #13 (permalink)
fans runs
Thanks again. You never know. Could be relay and thermo. Won't know until I replace the relay. Hope it's not thermo. Just change it several weeks ago.
