a urgent question about crankshaft pulley - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2004, 09:29 PM   #1 (permalink)
View stanleyeye's Photo Gallery
When I installed the crankshaft pulley, I found its groove was not aligned with timing mark"0" of the No.1 timing belt cover.
How can I set it back to TDC? Just turn the crankshaft pulley 360 degree or 720 degree?
Thanks a lot for your help!
stanleyeye is offline   Reply With Quote
Old 11-26-2004, 09:41 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Just turn the crank pulley clockwise till it lines up at 0.
What exactly are you trying to do? Install a timing belt?
"Skoolin' the unlearned!"
Old 11-26-2004, 09:50 PM   #3 (permalink)
yes, I want to install a timing belt.
So, I just need to turn it 1 revolution or 2 revolutions?
Thank you for your help, 88 LE,
Old 11-26-2004, 10:00 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
It doesn't matter. TDC is TDC, doesn't matter if its TDC on compression or exhaust stroke. The engine will figure it out when you fire it up.
So just turn the crank pulley clockwise till the notch on it lines up with the "0" mark on lower timing belt cover.
After you get the belt installed you'll need to rotate the crank 2 full turns (720 degrees), to check the crank and cam alignment.
This is because the cams rotate at half the speed of the crank. 360 degrees of crank rotation = 180 degrees of cam rotation.
Since its a 4 stroke engine its take 720 degrees for a complete cycle (compression and exhaust). 720 degrees of crank rotation = 360 degrees of cam rotation.
Old 11-26-2004, 10:07 PM   #5 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
What 88 LE said.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 11-26-2004, 10:13 PM   #6 (permalink)
got it, thank you so much!!!
admire,
