Increasing The Air Inside The Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2004, 12:33 AM   #1 (permalink)
View AFS_779's Photo Gallery
Hi My Friends..................
Every Body Know That More Air Inside The Engine Means More Fuel To Burn Which Lead To Increase In Power And Acceleration.
But Did Any One Notice What About the Fuel Economy .
My Question Is If I Install A New K&N Filter To Increase The Amount Of Air That Inters the Engine Will it Consume More Fuel Or Less.
And What Is The diffrence Between The Stock And The New Filter In Milage ( Distance For Car To Run In A Full tank)
AFS_779 is offline   Reply With Quote
Old 11-27-2004, 12:39 AM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
wtf..? thats like self explanitory.. more horsepower=for sure increased gas consumption.. but in this case it wont change ur hp by anything anyways so u will barely see any change in the fuel consumption anyway...
Corollacrazy42 is offline   Reply With Quote
Old 11-27-2004, 11:53 AM   #3 (permalink)
[K][a][M][r][Y]
View KamryStylez's Photo Gallery
Yeah more power means more gas wasted, but a filter isnt really heavy mod, actually cant even feel any difference. Go turbo or supercharge and u will feel the burn in your wallet and gas lol
95 Camry v6 LE
Cardomain: http://www.cardomain.com/id/kkkamryyy
KamryStylez is offline   Reply With Quote
Old 11-27-2004, 12:43 PM   #4 (permalink)
Gameroom cash: $147537
You said it already.
Old 11-27-2004, 12:56 PM   #5 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Efficiency.
amerikim is offline   Reply With Quote
Old 11-28-2004, 02:57 AM   #6 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
not really.... depends on how fast the air is entering inside your car.... if its coming in a little bit faster than normal, but nothing like a supercharger, it should increase gas mileage... go buy the k&n air filter, it shouldnt increase no more than 5hp, do a MPG test, i garuntee an increase of something...
MadDawg is offline   Reply With Quote
Old 11-28-2004, 03:25 AM   #7 (permalink)
migoreng's Avatar
View migoreng's Photo Gallery
k&n filters are designed to make your airbox work like its running without an air filter and with excellent filtration. so increases depend on how restrictive your stock filter is
migoreng is offline   Reply With Quote
Old 11-28-2004, 07:18 AM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
does it hurt to press the shift key so often? thats also quite hard to read.
go the K&N filer if you plan to clean it. NOTHING ELSE, you wont notice any power difference/milage difference after 10km or so after you put it in.
terrastrife is offline   Reply With Quote
Old 11-28-2004, 09:13 AM   #9 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
thats not completely true... You do sometimes gain fuel economy when you up the effciency of your more... An engine is nothing but a air pump ... If you make it breath better and flow better, that makes the engine more effcient... By doing so ups the fuel mileage per gallon...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
