3VZ-FE water pump no gasket??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2004, 10:36 PM   #1 (permalink)
View 94_v6_camry's Photo Gallery
Hi,
If there is a leak on my GEN3 Camry will a compressor water test show the results??? I suspect is the water pump, and speaking of water pump correct me if i am wrong there is no gasket for the water pump on the 3VZ-FE engine right???
Thanks
94_v6_camry is offline   Reply With Quote
Old 11-28-2004, 10:43 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
It uses seal packing...part no 08826-00100..that is water pump to cylinder block
amerikim is offline   Reply With Quote
Old 11-28-2004, 10:46 PM   #3 (permalink)
seal packing?? is that the same as RTV sealant???
Old 11-29-2004, 12:05 AM   #4 (permalink)
amerikim's Avatar
Cannot say for sure, but you have to work fast as it gets hard quick.
