turn signal malfunction HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2004, 04:31 PM   #1 (permalink)
View cycleguy77's Photo Gallery
USA turn signal malfunction HELP!
I have a 1992 toyota camry v6 that has a problem with the turn signals. I had a bad bulb in the right front signal that was bad and after replacing it with a new one the turn signals didnot work at all. I checked to see if the fuses were good but did not see a fuse for the signals. My hazards work fine, just my blinkers do not work at all. Before I repaced the bad buld they did work in the remaining three signals, if anyone could help with this would be great.
Thanks
cycleguy77 is offline   Reply With Quote
Old 11-30-2004, 01:07 PM   #2 (permalink)
Gameroom cash: $304355
Take the bulb back out and take a look inside the socket. Are the tangs broken off the bottom of the socket and is the piece broken off touching anything inside of there? Are the tangs high enough to contact the bottom point(s) of the bulb? Is there any rust inside the socket that needs to be cleaned? Also, check the fuse(s). And, by all means, make sure you replaced the bulb with the correct bulb, not just one that seemed to fit the socket.
Good luck with the problem.
Mike
