cheap mods for a stock camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2004, 01:13 AM   #1 (permalink)
View timmythturtle's Photo Gallery
I own a 1992 V6 camry w/ 110,000 miles on it which is still stock except for some recent work on the engine head and mostly new parts for the cooling system (this work was done because the car severely overheated damaging the head and blowing the head gasket). I have an optima redtop battery an autopage alarm that I installed and I am finishing up my sound system. I am a highschool student and I am on a small budget but with christmas coming around I could ask for more expensive stuff.
I am wondering where to start with my car. I have full access to the auto shop at my school so I can do any mechanical work.
Thanks everyone
timmythturtle is offline   Reply With Quote
Old 11-30-2004, 03:24 AM   #2 (permalink)
migoreng's Avatar
View migoreng's Photo Gallery
you should start with air intake and doing something about the exhaust system...
migoreng is offline   Reply With Quote
Old 11-30-2004, 03:41 AM   #3 (permalink)
engineer in training
Gameroom cash: $145055
well first here is some info on your engine, your engine is called a 3VZ-FE its a 3 liter v6 with economy dual overhead cams
some great mods for this engine are:
-get a new better flowing y-pipe installed
-get rid of your cat, or buy a high flow
-clean your intake, this involves removing most of what you see on top of the engine, it will help a decent amount cause let me tell you the exhaust recirculation system on the 3VZ dirties the intake a huge amount!
-make your own cai, this wont add too much power but the sound is amazing! you can use a variety of thing to do this, i used some 3'' aluminum electrical pipe i found at lowes and completly removed the intake from the throttle body all the way into the fender, there are a lot of resonators and junk that can come out and just run the intake into your fender, not that hard
-kill your egr system, you will need to block this off at one or two points along the system, the egr (exhaust gas recirculation) can be easily disabled if you end up cleaning your intake cause you have to remove the plenum, there is a pipe on the back that should be copper or brass colored, all you do is detach the plenum and before you put it back on fabricate a piece of metal to go in between the pipe and the plenum that will completly block the flow of any gas
-port your acis, this will help some and its easy to do! do a search in these forums for free v6 mod and you will find detailed instructions on cleaning your intake and porting your acis
good luck and welcome to TN!!
Old 12-01-2004, 07:47 PM   #4 (permalink)
how do i go about killing the egr system? i cant find anything under free mods bout that. and about how to port my acis. where is the y pipe located and what is it? and can i just take my cat out or how do i go bout doing that? sorry im not to familiar with this stuff but im a quick learner so any help would be great
Old 12-01-2004, 09:46 PM   #5 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Metal block bolted on the inlet's on the intake = blocked, or all plugged holes = blocked.
You can gain a tiny bit by cutting a hole in the bottom of the stock filter box, and/or enlarge the stock CAI pipe.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 12-01-2004, 11:08 PM   #6 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Blocking the EGR throws a check engine light....
97camryman is offline   Reply With Quote
Old 12-02-2004, 12:04 AM   #7 (permalink)
not on 3vz-fe camrys
Old 12-02-2004, 02:00 AM   #8 (permalink)
any drawbacks to blocking off the egr system? uhave any pics of what exactly needs to be blocked? im looking in my haynes for pics but im not too sure what needs to be blocked off
im planning on cleaning my acis and possibly my intake too. is there anything else i have to do to my acis besides clean it? do i have to grind down any metal on it? i read the forum but im not posative on that part.
Old 12-02-2004, 03:12 PM   #9 (permalink)
View Admiral93's Photo Gallery
the Y -pipe is a part of your exhaust system that links both your heads to one pipe the on on the gen 3 camry is goofy as hell and doesnt flow partiularly well.
93 LE V6, big plans. . . no money (isn't college great?)
Admiral93 is offline   Reply With Quote
Old 12-02-2004, 03:33 PM   #10 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112750
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Invest in a Haynes Manual, read up and get to know your car.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 12-02-2004, 03:42 PM   #11 (permalink)
Toysrme's Avatar
Cool
Combustion temperatures will be hotter and there will be cooler air in the intake and less exhaust buildup in it. All three of which can easily be argued to give you bits of power that are being wasted.
Now with Turbo!
Old 12-02-2004, 03:48 PM   #12 (permalink)
i own a haynes manual and im doing what i can to read about differnt parts of the car but crap the books like 2 inches thick. i put my car up on a lift today and i found the y pipe. admiral, you are right it is very akward. i was confused about how its supposed to help the air escape when the rear header exhaust joins the front header exhaust at almost the complete opposite direction. like one is flowing against the other. i can see how that could make a difference to switch it out. how much do they run and where can i get a new one?
any help with pics or more in depth info about blocking off the egr system would be great. thanks
Old 12-02-2004, 04:12 PM   #13 (permalink)
The Other White Meat
terrastrife's Avatar
thats done to make both header lengths equal to keep teh gases balanced or whatever, if you make a new one, just keep the same design but bend it nicer
tehre is no aftermarket stuff for a 3vz, make it all yaself.
terrastrife is offline   Reply With Quote
