how bout me? i have 2 DVC subs that i want to hook up to my 4-channel amp.
specs of amp:
2-, 3-, 4-channel or Tri-Way output
MOSFET power supply
50 watts RMS x 4 channels or 190 watts x 2
90 watts x 4 into 2 ohms
0-18 dB bass boost at 45 Hz
speaker-level inputs
variable (55-5,500 Hz) high-pass/ low-pass crossover, 12 dB/octave
dimensions: 15-3/4"W x 2-5/16"H x 8-1/2"D
specs of subs:
Polypropylene Woofer Cone w/Titanium Deposition Coating
Dual 4 Ohm Voice Coil
Stamped Steel Frame
Heat Resistant Voice Coil
Kapton Bobbin
Rear-Vented Pole Piece
Rubber Surround
Inverted Dust Cap
Large Strontium Ferrite Magnet
500 Watt Maximum Music Power
a)???
-OR-
b)???
-rayray
