Two things it is most likely to be:
1: Heater core bypass door... Controlled either directly by cable from the climate control or in an electronic system by an actuator. Located in the HVAC unit under the dash.
2: Heater core flow valve... Again controlled either directly by cable from the climate control or in an electronic system by an actuator. Located next to the firewall trace down the hoses that lead from the engine to your firewall, one will have the valve on it with a cable coming out from the firewall that opens and closes it.
It isn't very likely the heater core itself is bad unless it is plugged up with crap. The other way your heater core would be bad is if it were leaking, in that scenario you would probably still have heat, but you would also have fogging windows and most likely would be able to smell antifreeze. I've covered troubleshooting in other posts, do a search on "climate control".
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
