Tire rumble during left turn or road curving left - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2004, 01:36 AM   #1 (permalink)
5spd V6 ClrTail's Avatar
View 5spd V6 ClrTail's Photo Gallery
On the highway, if the road curves left, I get this pretty loud and annoying tire hum, when the road straightens, the noise goes a way. This also happens when I change the lane to the left. It's like I could play around w/ the noise on the highway, if I turn the steering slightly left the humming starts, steering straight no noise. What could this be, alignment problem? Car rides pretty straight, if I let the steering go, starts to move left, but slowly. The noise obviously comes from the right rear.
5spd V6 ClrTail is offline   Reply With Quote
Old 12-01-2004, 03:49 AM   #2 (permalink)
View karazy's Photo Gallery
If the tires are all good, then I would suspect a bad wheel bearing.
karazy is offline   Reply With Quote
Old 12-01-2004, 07:44 AM   #3 (permalink)
View dallison's Photo Gallery
loose lugnuts? but you would most def feel that one
1989 camry ghetto sled
dallison is offline   Reply With Quote
Old 12-01-2004, 12:37 PM   #4 (permalink)
Gameroom cash: $304355
Try switching the 2 front tires with each other as a test. If the noise goes away or if the noise is now happening on the right side, then the tire switched to the right side is the problem. If the noise remains, then you have eliminated the front tires as the problem.
Mike
Old 12-01-2004, 01:22 PM   #5 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
im goin with wheel bearing
Hatch is offline   Reply With Quote
Old 12-01-2004, 01:58 PM   #6 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
maybe it sthe CVjoint
check your CV joint..
You'll like being blown
Bunthy is offline   Reply With Quote
Old 12-01-2004, 06:38 PM   #7 (permalink)
I know it's the Right Rear side. Wheel bearing you think? How much?
Old 03-02-2005, 08:49 AM   #8 (permalink)
Whats the difference between wheel bearing and hubs. In this case which do I need to change and how much would it be? Right rear wheel hums and rumbles when weight shifts on it. Also, that wheel is becoming bald. I think worn wheels make more noise, but this is too much. Or maybe it's just the alignment? Any way, if it's the wheel bearings or hubs, how much $ would it be?
Old 03-02-2005, 06:24 PM   #9 (permalink)
What does the wheel bearing look like. Or the Hubs. How much would it be to change this or get it fixed.
