'Lotta cars just use ATF fluid for powersteering fluid. If yours says use ATF only(or Dexron II or II) just use a higher grade synthetic ATF fluid. AMSoil, Mobile 1. Good stuff!
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
^^ What he said.
As for powersteering service: I do a lot of preventive maint. When my camry turned 70Kmiles, i had the dealership to the timingbelt replacement. There you can talk to the service tech and they can add powersteering belt replacement and alternatorbelt replacement for a price (for me those two were $24 in addition to the timing belt changing price; keep in mind those belts cost close to 12 bucks a piece, so the labor was not included as it was all entailed in the timinging belt replacement). I paid $224 for all three belts at toyota (keeping in mind i had coupons, and take all my cars there).
I had power steering leaks --on rack I believe -- 97 Camry LE -- I bought Lucas stop leak steering product & it works! . Not sure how compatible as they don't give much tech detail . It is awfully thick in winter cold (-40!) & restarted leaking last winter . Been good again all summer . I may go back to ATF for the winter . BTW I never flush olds stuff -- waste of time I think.
I will check out the word on this site where some really knowledgable people answer I used to use ATF in winters in dashpots of SU carbs for the same cold weather viscosity issues http://theoildrop.server101.com/cgi/ultimatebb.cgi
If it says Dexron II, or III, or ATF, use Dexron III ATF. Do not use power steering fluid. Power steering fluid is available at stores, but that is not what your car uses obviously.
