Well,
Headers are the pipes that connects exhaust manifolds of the engine to the catalytic converter... Replacing headers don't do much unless you replace entire exhaust system such as hiflow catalytic converter and performance muffler... Even with this there is a drawback because you loose the back pressure... Only good thing is that you get louder exhaust noise. Obviously if you put in turbo, you need a new header or modify the factory one... I hope this helps.
99 Solara SE V6
-19" Konig Tantrum rims, TRD springs, K&N filter, aluminum pedals (All sitting in my garage...)
