Fuses or Fuse I'm Confused - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2004, 01:24 PM   #1 (permalink)
View pb111's Photo Gallery
I have a 1999 Toyota Camry 3.3 LE
Does the Radio Back Light
Ash Tray Light
Cig Lighter
all work off of one fuse?
And if so Any idea where I could find it?
Thank You in Advance
Paul
pb111 is offline   Reply With Quote
Old 12-03-2004, 01:27 PM   #2 (permalink)
View karugs's Photo Gallery
I do not have that car but when the radio, clock, and cig lighter on our 95 Corolla went out because I installed a different cig lighter I checked the fuse and it was blown.
Easy to check and repair. Did you do anything prior to that?
karugs is offline   Reply With Quote
Old 12-03-2004, 04:12 PM   #3 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Those are all controlled by the dimmer rheostat (check if turned down) They are in most cases tapped off the tailights, make sure they are working. Have you done any stereo system changes lately ??
CraigW is offline   Reply With Quote
Old 12-03-2004, 08:54 PM   #4 (permalink)
Reppin my Home
troy's Avatar
View troy's Photo Gallery
I believe it's all one fuse.. check the panel to the lower left of the steering wheel, there should be a panel that pops off where the fuses are.
Try changing the fuses first, probably a 10A or 20A mini fuse.
troy is offline   Reply With Quote
Old 12-04-2004, 02:38 AM   #5 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
It is the dome light fuse. Under the hood.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 12-04-2004, 02:59 PM   #6 (permalink)
Eaten iVtecs before!
View coolchu001's Photo Gallery
userlain is right about it, i've messed with the stereo power and everything blew out in the interior. Replaced the dome light fuse under the hood fixed the problems
coolchu001 is offline   Reply With Quote
Old 03-16-2005, 07:39 AM   #7 (permalink)
View fernicus's Photo Gallery
on a related note, anyone tell me where the fuse for the dimmer switch is? Can't find it for the life of me and I don't have a manual for my car right now.
fernicus is offline   Reply With Quote
