Rear Caliper Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2004, 03:32 PM   #1 (permalink)
View comme26's Photo Gallery
I brought my 99 Camry to a mechanic and they said my rear calipers were seized. They said it will cost about $84 Canadian to fix each one. Is that a good price? Someone told me that the only way to fix seized calipers is to rebuild them or get new ones. Is that true? I asked my friend to check to see if the rear calipers were seized, and he said I had to take them off to check and that was the only way. Is there a way I can check? If I have to rebuild my calipers, do you think it is better to buy already rebuilt calipers(costs me less) or get the mechanic to rebuild the ones I already have(costs more)?
comme26 is offline   Reply With Quote
Old 12-03-2004, 05:34 PM   #2 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
^^took my advice and joined huh?
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 12-03-2004, 06:08 PM   #3 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Doing a capiler job yourself is not a big deal, unless you are completely mechanically uninclined.
Do you have any junkyards around you? You might want to check for a set of rear calipers there.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 12-03-2004, 07:59 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Easy way to check. Take the bolt out and flip the caliper up. Have a buddy push the brake pedal. The piston should move when the pedal is pushed.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 12-03-2004, 10:38 PM   #5 (permalink)
View karazy's Photo Gallery
It depends on how it is seized. If it's the piston, I prefer to replace them. Usually there is pitting and internal damage and it's not worth the trouble. I only recommend kits for leaks, caused by bad rubber. If it's just the slider, I would just clean and lube.
Most shops, that give free estimates, should show you what is wrong and explain what needs to be done. This saves you from getting cold and dirty.
karazy is offline   Reply With Quote
