Engine bay pic (which is the coil for 1st & 2nd cylinder? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2004, 08:34 PM   #1 (permalink)
View crave555's Photo Gallery
HELP!!!..(which is the coil for 1st & 4th cylinder?) *PIC
I am getting CHECK ENGINE codes P0300, P0301 & P0304.
Anyone knows which one are Cylinders 1 & 4?
Thanks,
crave
crave555 is offline   Reply With Quote
Old 12-03-2004, 09:39 PM   #2 (permalink)
SiennaSC98's Avatar
View SiennaSC98's Photo Gallery
Thanks,
crave
This is what I got from alldatadiy.com for my 1998 Toyota Sienna XLE (1MZFE 3.0L V-6 - same engine for Solara, Camry, Avalon)
Shown is LH cylinder head
Cylinder #2 is on the left
Cylinder #4 is on the middle
Cylinder #6 is on the right
RH Cylinder head (firewall side)
Cylinder #1 is on the left
Cylinder #3 is on the middle
Cylinder #5 is on the right
There are only 3 igniter coils and are all in LH cylinder head . One coil supports two cylinders. Coil at #2 for 1/2, coil @ #4 for 3/4, coil at #6 for 5/6. Firing order is 1-2-3-4-5-6
SiennaSC98 is offline   Reply With Quote
Old 12-04-2004, 12:09 AM   #3 (permalink)
Many thanks SiennaSC98
crave
Old 01-19-2006, 01:31 PM   #4 (permalink)
View davidkimchee's Photo Gallery
Newbie here. Resurrecting an old thread....are you sure about the coil to cylinder wiring??
I could have sworn #4 coil went to #1 cylinder.
Can someone clear this up. Can anyone with a shop manual confirm?
Thanks!!!
David
EDIT:
Forgot to add....if it is 4-1 same coil then it appears you have a faulty coil pack.
davidkimchee is offline   Reply With Quote
