Need Help changing Alternator on 99. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2004, 09:39 AM   #1 (permalink)
View ChrisGST's Photo Gallery
USA Need Help changing Alternator on 99.
Hi, I was wondering if their are any guides or FAQs on how to change the alternator on a 99 camry LE. Thanks in advance.
ChrisGST is offline   Reply With Quote
Old 12-04-2004, 10:32 AM   #2 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I recently changed mine and it was not hard at all. Well I have a '93 cam don't knwo how much diff it would be. It's basically taker it out put it in and make sure u'r belt has the correct tension. You can also take a look at this: http://www.autozone.com/servlet/UiBr...3d8013e1cd.jsp
http://www.xclusive.bz
Old 12-04-2004, 10:46 AM   #3 (permalink)
Thanks for the link but for some reason its not working when I try to change it to the 99 model. I'll just have to keep trying later. The bolts look easy but I am worried about the belt. I've never messed with belts before and was wondering if anyone has some advice/ tips.
Old 12-04-2004, 10:49 AM   #4 (permalink)
dna59's Avatar
I've never messed with them either before, but i took my chances and it came out good. If it's too tight you'll know cause it'll squeek. I don't think that they'll give you different instructions for a '99 because some of their info is just standard info they give.
Old 12-04-2004, 11:36 AM   #5 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Is it a serpentine belt ?? They are simple if you have the proper tool. Just be sure to make a drawing of its routing.
CraigW is offline   Reply With Quote
Old 12-04-2004, 12:29 PM   #6 (permalink)
Did it it was pretty easy thanks for the help.
Old 12-05-2004, 10:16 PM   #7 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Belts are nothing. They look all scary and complex until you realize its just a belt. You need to do this:
1. Disconnect vehicle battery.
2. Unplug wires going into alternator.
3. tape ends to prevent shorting out anything.
4. use a socket and ratchet to relieve belt tension.
5. use small breaker bar and socket to undo hinge bolt and remove.
6. unbolt alternator tensioning bolt.
7. remove alternator and reverse steps with new alternator.
8. When tensioning the belt use two rulers and get the specs off haynes repair manual. Or just tighten it until it feels right and doesn't flop around or slip.
Thats all that I can think of.
97camryman is offline   Reply With Quote
