Cylinder head interchange
I have a 1992 Camry with the 5S-FE engine that needs a cylinder head replacement. I bought a head from a wrecking yard and they told me it was for the 5S-FE but after I got it and measured the cam lobes I determined that it was for a 3S-FE.
I called the wrecking yard and they claim that the head castings are the same even if the cams are different. I measured the length of the valves and they are different so it looks like if the castings are the same I could use all of the parts (valves, springs, keepers, cams, etc.) from the bad head. Of course I would grind the valves and seats.
Does anybody know if the head castings are the same?
