Tire / RIM Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2004, 10:12 AM   #1 (permalink)
View s2tigger's Photo Gallery
Tire / RIM Question
I currently have a set of Axis - Lenso VPD RIMS - 17"/ 7" (Gunmetal) for my 1992 Toyota Camry.
The information for them is as follows:
The Factory Bolt Pattern - 5 x 114.3
Hub - 60.1
Offset - High
Lug - 12 x 1.5
Tires - 215/45 R17
I'm wondering is I can put 225/45 R17 tires on the same rims. If I can, I'm wondering if I'm going to have any problems with the 225/45 R17 tires on my car. (Will they rub, etc...)
Any help with this question would be greatly appreciated.
-s2
s2tigger is offline   Reply With Quote
Old 12-06-2004, 10:23 AM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
they fit fine on the car, thats what i have.... except i have a 7.5 wide rim... you should call your local performance tire shop and ask them if a 225 is ok for a 7 inch wide rim... you MIGHT want to just stick with the 215...
you need to fit the tire to the rim before you fit it to the car... in this case, either will fit fine for the car, just worry about the width of the rim..
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 12-06-2004, 10:23 AM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
225/45/17 will fit although not recommended (7.5"). Fitment on your car depends on offset.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 12-06-2004, 12:22 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
do it...it'll help fill up that wheel gap.....
I've got 225/45/17 winters on and no probs....I like how it looks too
HaHa
Old 12-06-2004, 01:27 PM   #5 (permalink)
View joel_musicman's Photo Gallery
Ummm... 225 = WIDER than 215 rather than TALLER. I know maintaining the 45 will mean a slight difference in the sidewall height, but it'll probably be only enough to throw off the speedo.
-Joel
My new baby! 2007 Toyota Camry SE V6 - Super White
'99 Camry LE, Reverse Glow Gauges, Strut Brace, & Infinity Basslink
joel_musicman is offline   Reply With Quote
Old 12-06-2004, 02:50 PM   #6 (permalink)
I'm a Mac
zoni's Avatar
actually bro, its both... the first number is the width, but the second is a ratio... its dependant on width... so if you have 225/45, its going to be wider AND taller than a 215/45
Dave Zoni
Old 12-06-2004, 03:34 PM   #7 (permalink)
Okay,
so I talked with a guy at Axis (http://www.axiswheels.com/) and he said that the 225/45 17s will fit on the 7" VPDs. I see that E.8.P. says they fit on his car with no rubbing. SO, does anyone else have 225/45 17s on their car? And if so, are they on 7" rims or 7.5" rims. As far as the speedo goes, check this site out:
http://www.miata.net/garage/tirecalc.html
Based on a stock tire size of 195/70 14 and a new tire size of 225/45 17 when my speedo reads 60mph I will actually be traveling 60.5mph. No big deal. ;-)
Do any of you have Goodyear Eagle F1 GS-D3s?
(http://www.tirerack.com/tires/tires....omCompare1=yes)
-s2
Old 12-06-2004, 05:04 PM   #8 (permalink)
TN Pussy Man
actually, the 215/45/17 also throws off your speedo if you want to be anal about it....just as much as the 225/45/17 does....
and I run mine on 7" rims
HaHa
Old 12-06-2004, 05:33 PM   #9 (permalink)
Rocket Surgeon
woody's Avatar
View woody's Photo Gallery
I put 215/50 17 onto my 98 works great, lotsa clearance, and the right amount of rubber in the wheel well
woody is offline   Reply With Quote
Old 12-06-2004, 09:16 PM   #10 (permalink)
Eaten iVtecs before!
View coolchu001's Photo Gallery
i got 225/45/17 on my 17x7" ADR wheels, they work fine, no rubbing or anything...
coolchu001 is offline   Reply With Quote
Old 12-13-2004, 10:53 PM   #11 (permalink)
View to_cam's Photo Gallery
Canada
All of you guys seem very knowledgable in car rims compatibility. I just bought a 03 Camry LE and never was able to find out what the wheels offset was for the car. Hoping that someone here can answer this question that I have asked many about.
I have an offer to purchase and the specification follows: Diameter is 17", Width is 6 1/2, Offset is 55mm, Bolt pattern is 5x114.
Victor
to_cam is offline   Reply With Quote
Old 12-13-2004, 10:57 PM   #12 (permalink)
Basically my question is would those rims with the specification above fit my 03 Camry LE? Thank you!
Old 12-13-2004, 11:09 PM   #13 (permalink)
Thanks TN..
http://www.toyotanation.com/faq/faq....prog=1&lang=en
Gen5:
Bolt pattern: 5 x 114.3
Offset: +50mm
So the question is will the Camry with Offset of +50mm fit rims for the following specifications: Diameter is 17", Width is 6 1/2, Offset is 55mm, Bolt pattern is 5x114.
Old 12-14-2004, 04:13 PM   #14 (permalink)
campfire9's Avatar
View campfire9's Photo Gallery
tire size
If you want to find out the substutits tire for your rim so it will have the same or very close to the actual spdo and miles run, go to 1010tires.com. click on the tire size calculator and you can play with it and come up with the right tire.
My 205/60R16 can be replaced by 225/55R16 so at 60mph on my old tires I will be going 59.8mph with the new.
Campfire9
campfire9 is offline   Reply With Quote
