How big are those spark plug tube nuts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2004, 10:32 PM   #1 (permalink)
Eaten iVtecs before!
View coolchu001's Photo Gallery
Question How big are those spark plug tube nuts?
Well since i've just purchased a valve cover gasket w/ spark plug tubes, how big of a socket do i need to remove those 4 nuts where the spark plug wires go into?.....are they like 30-32mm or something?...i've heard they are 30mm, but the store only has 32MM will that work?
coolchu001 is offline   Reply With Quote
Old 12-06-2004, 11:25 PM   #2 (permalink)
Gameroom cash: $147537
30mm if you can't get a socket, get a big wrench., adjustable one.
Old 12-06-2004, 11:39 PM   #3 (permalink)
Formula One Fanatic
andyman61's Avatar
View andyman61's Photo Gallery
yup, 30 mm is correct. try car quest, i think that's where we got the right size socket for when we replaced the valve cover gasket on my car.
Metal to burn, sparks to fly...
1992 Toyota Camry 5 Speed - 5S-FE....totally stock
andyman61 is offline   Reply With Quote
Old 12-07-2004, 04:23 PM   #4 (permalink)
sooo you think a 32mm would work?.....i cant seen to find any 30mm.....i've found a 1 1/8" being close..but thats like only 28mm....so i guess a bit bigger would be ok?
Old 12-07-2004, 04:41 PM   #5 (permalink)
View gcs118's Photo Gallery
Try AutoZone. I got my socket from them, but it's part of the rent a tool program so you have to specially ask. The large nuts on top of the valve cover for your 1992 Camry are the same size as the hub nuts on the front wheels. So you'd have to ask for the 32mm or (30, whichever) hub socket, and it'd work for the others as well.
gcs118 is offline   Reply With Quote
Old 12-07-2004, 05:30 PM   #6 (permalink)
Moving Forward
View Cyorke's Photo Gallery
I jsut have a question. Are you replacing the spark plug tubes also. If so may I ask why? They are steel and should not need to be replaced. If you paid for them you should take them back. When you remove the tubes you can clean them very well with a wire wheel and then reseal them. We used to do it all the time when I was a tech. Unfortunately that has been about 6 years and I dont rememebr what product we used to reseal them. All I can tell you was it was a brown bottle with yellow lettering and if you get it on you it is a bitch to get off. You may want to call your local dealer and ask them what they use for this. NO reason buying something you don't need. Just you a good pair of channel locks to unscrew them making sure not to crush tehm obviously.
Just my 2cents.
Cyorke is offline   Reply With Quote
Old 12-07-2004, 07:39 PM   #7 (permalink)
well the gasket for the valve cover was $17.xx and with the spark tubes were only $2 more so i gotten that since the tubes usually cost around $6-8
Old 12-07-2004, 09:12 PM   #8 (permalink)
Moving Forward
makes sense then. Like I said we never replaced them so never knew how much they cost. But hey for 8 bucks you might as well.
Old 12-08-2004, 02:57 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
No.
You need a 30mm socket or a big adjustable wrench.
Try Sears, they sell sockets individually.
"Skoolin' the unlearned!"
