lighting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2004, 12:42 PM   #1 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
USA lighting
ok i'm trying to buy some leds for my lighting and i got a couple questions
1. Is a 2825 bulb the same as a 194 or a t10 bulb?
2. How do i get that grey piece off that covers the map lights? i almost broke my fingers trying to get it off.
3. Any suggestions on how to get to the license plate bulbs?
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 12-07-2004, 04:19 PM   #2 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
i could probably help with #3, i have no idea about #1 or #2 though
to get to the licence plate bulbs you need to remove the boot/trunk trim. just pull out some of those plastic pegs/screws out using a pair of plyers. as long as you put them straight out they shouldnt break . you can either remove the whole trim piece or just bend it enough to change the bulbs
good luck with everything
~ Terry
terrynham is offline   Reply With Quote
Old 12-07-2004, 07:29 PM   #3 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
A # 168 bulb is brigter than # 194 bulb and the #2825 bulb is the brightest. They are all the same (virtually) physical size.
The 03+ Corollas started using 168s for license plate lights (all before were 194) The #2825 is used as the license plate lights on the New Beetles.
CraigW is offline   Reply With Quote
Old 12-07-2004, 09:32 PM   #4 (permalink)
The Cool Guy
oh wow thanx for the info......now for question 2 and i'll be all set.
Old 12-07-2004, 09:41 PM   #5 (permalink)
metamorphosis
cman2000's Avatar
View cman2000's Photo Gallery
2. map light cover. not sure for your 2002, but for my 2000, i used a flat-head screwdriver, and slowly pryed the cover off. with a little force, it popped out. and to put it back was as easy too. hope it's the same for your Gen 5. good luck
cman2000 is offline   Reply With Quote
Old 12-08-2004, 11:12 PM   #6 (permalink)
The Cool Guy
hmmm i was looking at the trims.....is the trunk piece that i have to take off one with a keyhole? i'm so noob. where is this exactly at. inside the trunk? outside? x_x'
Old 12-08-2004, 11:52 PM   #7 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
its that grey trim inside on the underside of the trunk lid
your car manual should tell you how to remove it....i scanned my one below by the way
~ Terry
Old 12-09-2004, 03:18 PM   #8 (permalink)
The Cool Guy
omg all that just to change some leds! lol! okkkkkk i'm up for it.
Old 12-14-2004, 05:13 PM   #9 (permalink)
The Cool Guy
ouch my fingers hurt.....i tried pulling the lil plastic screws things off with a flathead but they just wouldn't come off.......do i twist them or something?
My map lights piece sounds like it's cracking when i pull it out......man. the car manual says to get a toyota dealer to do it if they go out. that sucks.
Old 12-14-2004, 05:49 PM   #10 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
you will also need some plyers aswell to help get them off
use the flathead to put it out a tiny little bit, then stick the plyers inbetween (into that gap you just made) and then pull it out that way
~ Terry
Old 12-14-2004, 06:02 PM   #11 (permalink)
View cam98hi's Photo Gallery
anyone have a clue what would fit in a gen4 - which blub for the plate?
`. Gen4 . `
cam98hi is offline   Reply With Quote
Old 12-14-2004, 07:45 PM   #12 (permalink)
The Cool Guy
ah i see........it's no wonder.......they were being resistant to my power! lol. ok i'll try it.....doesn't help that it's 50 degrees outside =/
plus that map light still giving me trouble.......argh!
Old 12-15-2004, 03:25 PM   #13 (permalink)
The Cool Guy
argh! the thing doesn't come out so smooth! i broke the plastic screw......now i'm hesitant to try anything........crapp
Old 12-15-2004, 06:39 PM   #14 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
it should come out pretty smoothly.....
if you use the plyers as a lever, instead of trying to pull the screw out with force, it should come out no problem , if it is hard, your doing it wrong
in the pic i did below, just push the plyers up at the end, and then the screw should come out straight, so thus it shouldnt break....
~ Terry
Old 12-15-2004, 08:22 PM   #15 (permalink)
The Cool Guy
my plastic screws doesn't look like that........it has a little cross in the center where you can put a screwdriver? for some reason........iono. i should did break that other one
