Rev limiter romoval - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2004, 02:35 PM   #1 (permalink)
View tskelton1211's Photo Gallery
Rev limiter romoval
hey...i have a 1998 toyota camry 2.2 l 4 cyl...5sfe i guess
i have been seeing things about rev limiters but i have no idea what they are...does is affect my trottle response, top speed, etc??? i have searched and all that has done is confuse me more...can someone help? also, is there a way to remove it????
thanks
tskelton1211 is offline   Reply With Quote
Old 12-07-2004, 03:18 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
For starters, it doesn't effect any other system in the car. It only works when you hit..redline.
Second, don't remove it. You risk damage to your engine, that is unneccessary. There is NO power at that RPM range (above 6000 and beyond) so why remove it? Unless you've got a modified motor which produces it's power at these engine speeds...
Different types work in different ways, but I believe the Camry uses a spark cut type.
Basically what that does is, when you get your RPM to redline (i'm not sure what the 5SFE is..6200??) the ECU purposely cuts spark to some cylinders, which stops the engine from increasing its speed any furthur.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 12-07-2004, 04:26 PM   #3 (permalink)
ok cool thanks...imi kinda confused though bc today i was going on a long open road...flat...and long...i got up to only 95 decently quickly and then my car just kinda went dull...it didnt like jolt but i wouldnt think it would get cut off that fast...any ideas???
Old 12-07-2004, 04:39 PM   #4 (permalink)
View gcs118's Photo Gallery
May be a few things. Chances are the wind resistance by that point was hindering your car's acceleration. Also, though, some cars have a speed limiter instead of a rev limiter. Not positive on your application. The different kinds of limiters/governors can either be hard (sudden jerk and speed loss) or soft (speed simply does not increase any further). Hope this helps somewhat.
gcs118 is offline   Reply With Quote
Old 12-07-2004, 05:31 PM   #5 (permalink)
what is a speed limiter and how could it be removed???
thanks for the help!
Old 12-07-2004, 06:02 PM   #6 (permalink)
99 Camry LE
View Gachinto's Photo Gallery
i've purposely tried to max my 99 camry 4cyl a/t ... with with o/d off ... tat means 3rd gear ... at rev limit @ 6200 ... speed was 185km/h ~ and i went a lil higher with o/d ~ so i dunno y u wanna remove the rev limiter ... the stock camry has no power for u to redline with o/d :P well ... maybe there is but ... so far there's no road for me to do so yet
Gachinto is offline   Reply With Quote
Old 12-07-2004, 06:20 PM   #7 (permalink)
Urban Nomad
Alpha's Avatar
View Alpha's Photo Gallery
the rev limiter is there for a reason, as people said previously, you'll run the risk of seriously damaging your car if you somehow manage to disable it. I have no idea how you'd take it off, but i know that it isn't the smartest thing to do.
Alpha is offline   Reply With Quote
Old 12-07-2004, 06:45 PM   #8 (permalink)
The speed and rev limiter would be part of the ECU. Rev limiter is definitely a good thing in my opinion. Speed limiter...I'd be willing to bet your car is limited by air drag. If not, that is also regulated by the ECU.
Old 12-07-2004, 06:51 PM   #9 (permalink)
ok cool...thanks everyone
Old 12-07-2004, 07:16 PM   #10 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
it keeps you from blowing up your engine and you from sueing the manufacturer.
MadDawg is offline   Reply With Quote
Old 12-07-2004, 07:27 PM   #11 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Most Toyota's have both.
They limit RPM with an RPM limiter
They use wheel speed sensor's to detect speed
All that needs to be done to defeat either is to intercept the signal, and reproduce whatever signal you want.
The RPM limit can be fooled, but it is counter-productive and just a stupid idea
The wheel speed sensors signal can be frozen with no ill-effect, if done at a high speed. (above the last gear change speed)
Depending on the car there is a pickup on the transmission which also sends a speed signal to the ECU.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 12-07-2004, 08:33 PM   #12 (permalink)
awesome thanks
Old 12-07-2004, 09:11 PM   #13 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
only way around it, stand alone
Porkch0p220 is offline   Reply With Quote
Old 12-07-2004, 09:17 PM   #14 (permalink)
Toysrme's Avatar
Cool
No. There are a few piggybacks that can deal with it...
Besides unless you're planning on making insanely large amounts of power. (more than 450cc injectors) What reason is there for a standalone? You've just made things many times more complex for yourself, and eliminated all of the beautiful tuning of the motors. (the ability to deal with an unlimited variaty of conditions)
Now with Turbo!
Old 12-07-2004, 09:28 PM   #15 (permalink)
hey...i actually have a JET V force piggy back which should be here either tomorrow or thursday....im hoping i can speed it up...
