brake pedal problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2004, 08:57 PM   #1 (permalink)
View lam_jai's Photo Gallery
Canada brake pedal problem
hey...i need some help here... i got a 2002 camry Le... and the problem i'm having is the brake pedal vibrating..shaking..rattling..rumbling.. i don't know how else i can put it..just vibrates a lot... when ever the car is stopped the brake pedal starts to vibrate on my foot... it doesn't always happen but often.. is there any suggestions? my car just passed the warantee..><" it doesn't shake or vibrate when the car is stopping or driving.. but when the car is fully stopped..anyone know what the problem is? and what can i do to fix it?. it starts...i need some help.. thanks...
lam_jai is offline   Reply With Quote
Old 12-07-2004, 09:13 PM   #2 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Sounds like warped rotors ?? How many miles ?? Pads replaced / rotors turned ??
I dont turn my rotors anymore just seems to kill them, I run them until they exibit the symptoms you are describing and then replace them.
CraigW is offline   Reply With Quote
Old 12-07-2004, 09:31 PM   #3 (permalink)
i just did a brake job..last month...and i replaced pads with new..machined rotors..and adjusted drums... and the pedal shook when the car is stopped..not when it's stopping...so...yea....
Old 12-07-2004, 09:59 PM   #4 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
OEM rotors or drilled+slotted rotors? Ceramic pads?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 12-07-2004, 10:37 PM   #5 (permalink)
Double
View crah's Photo Gallery
I don't think you have a rotor issue if it's doing it at idle. Warped rotor symtoms appear while you are stopping not at idle. If you feel vibration coming from you peddle at idle, that could be caused by various reasons. You need to give a little more detail on the exact condition. Does your tach show that your idle is fluctuating, does your engine shake etc. Any other information will help. Did you have this problem prior to doing your break job?
crah is offline   Reply With Quote
Old 12-07-2004, 10:57 PM   #6 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
Usually when you experience vibration on idle & in gear is because of your motor mount.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 12-07-2004, 11:08 PM   #7 (permalink)
i had this problem even before i change my break pads and machining rotors.... i did it in school...and i asked my instructor but he said he doesnt know either....thats why i'm asking on the net cause i know there will be more suggestions up here and more pros....
Old 12-07-2004, 11:08 PM   #8 (permalink)
what can i really do?
Old 12-07-2004, 11:15 PM   #9 (permalink)
EKam's Avatar
^Take it to a reliable, trusted mechanic.
