Accellerator pedal goes too loose!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2004, 05:32 PM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
I've got an interesting problem with my accelerator pedal.
After drving the car in hot conditions, the accelerator goes....too loose.
Normally, you can feel a little resistance on the pedal. Which is good.
But when this problem happens, although the pedal returns fine to its resting position, wen pressing it, it almost feels like theres no spring or something.
It is connected via cruise control, so i was wondering I maybe a vacuum hose had something to do with it.
It is intermittant, so it will go back to normal for a bit.
In cold weather...doesn't do it at all.
What could this be??
Also, a different problem..my accellerator gets stuck sometimes...like I'll start the car after I've been driving it and the rpm's will shoot up to 2K 2.5K and i've gotta tap it a coupla time to get it back to idle. Ideas?
Thankyou
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 12-08-2004, 05:56 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
check your throttle cable.. and tighten it if needed
atobe is online now   Reply With Quote
Old 12-08-2004, 06:00 PM   #3 (permalink)
VeeZed
Done that already. Cable tension is quite stiff, that is..no slack.
Old 12-08-2004, 06:58 PM   #4 (permalink)
The Asian Sensation
View Xevuhtess77's Photo Gallery
hmm.... i have that problem sometimes too. after a lot of heavy driving my pedal feels kinda soft, and that it's not resisting my foot too much. mabye the spring mechanism gets stretched out after being used for a while?
Xevuhtess77 is offline   Reply With Quote
Old 12-08-2004, 07:03 PM   #5 (permalink)
VeeZed
Thats the thing though...it returns back to normal. So im not sure if the spring could stretch and the go back to it original tension?? Weird!
Old 12-08-2004, 08:04 PM   #6 (permalink)
The Asian Sensation
*shrug* i dont know if thats scientifically correct, could the spring do that? it's the best guess i've got though
