Wierd noise from front... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2004, 01:46 AM   #1 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
I searched and couldn't find this problem... I installed Tein lowering springs and Tokico struts last weekend and now my front struts towers make a groaning noise when I turn the wheel sharply. I have heard that it migh be the strut upper mounts but could it be the bearings? Did the springs not seat right? I cannot wiggle the springs, there is no popping and the bottom coil is in the proper dropped section of the strut. The noise is annoying but should I be worried? It only started after I lowered the car so I figured I probably messed something up. If it is the upper mounts what exactly does this mean, will I hurt anything, do they need to be replaced very soon? Please help.
97camryman is offline   Reply With Quote
Old 12-09-2004, 11:45 AM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
It sounds like the spring hasent completly settled in did you put the rubber piece back on the perch?
PM YESCA, I think he had the same problem... you may just need to grease the berrings in the strut mounts, in any case YESCA, theamazingnate and I can prolly help you as far as labor goes.
where in St.L you at?
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 12-10-2004, 01:12 PM   #3 (permalink)
97camryman's Avatar
I did put the rubber back on the perch. It is no problem to take it apart and grease it or replace anything but it will be awhile till I can. I am just wondering if I need to worry about damaging anything critical. It seems like just an annoying noise, squeaky, like a groan when I turn the wheel. Its not rough or any resistance. I am in St. Peters, just outside St. Charles area.
Old 03-28-2005, 09:06 PM   #4 (permalink)
CTCAMRY's Avatar
View CTCAMRY's Photo Gallery
i just installed my tokico and h&r, i have same noises when turning the wheel. how was this resolved?? thanks.
CTCAMRY is offline   Reply With Quote
Old 03-29-2005, 01:23 AM   #5 (permalink)
97camryman's Avatar
I just decided to ignore it. When it warms up outside it doesnt groan or squeak so I let it go.
