Lowering a little bit more - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2004, 03:22 PM   #1 (permalink)
Infamuz
View StreetMob's Photo Gallery
I already got a mean drop on my Gen 3 Cam, but i want to make it "look" even with the back ( Those who have dropped theirs know wut i mean) Is there any front springs out there that lower the front more than my 1.8 Dropzones????
http://www.cardomain.com/memberpage/391301
StreetMob is offline   Reply With Quote
Old 12-09-2004, 03:27 PM   #2 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
Not sure if there's any springs that give you a drop lower then the Dropzones. Save your money up and get coilovers. That should given you an even look since you can adjust the height.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 12-09-2004, 04:02 PM   #3 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
^ditto. If you dont care about having REAL coilovers you could always get just the sleeves. It will allow you to adjust your height...some people are VEHEMENTLY opposed to sleeves...ground control makes some of the better sleeves. do a google search for GC and see if they fit your application.
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 12-09-2004, 09:01 PM   #4 (permalink)
Infamuz
Thanx guys...ill check it out
Old 12-19-2004, 07:44 PM   #5 (permalink)
View juan01's Photo Gallery
Doesn't seem like there are any Ground Control sleeves for the 92-96 Camrys/ES300s. Would it be possible to modify the newer gen ones to fit on the older ones?
juan01 is offline   Reply With Quote
Old 12-19-2004, 08:59 PM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
buy a bodykit to look lower... gen3's are stupidly low even when they dont look it.
terrastrife is offline   Reply With Quote
Old 12-20-2004, 05:58 PM   #7 (permalink)
View wontonjohnny's Photo Gallery
agreed... i have dropzones and the frame rails have about a 4.5 inch clearance to the ground... and the drop is even... it jsut looks liek the front didnt drop enough because the wheel gap in the front is larger, for the wheels to turn.
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
