Hey guys, Im looking for your opinons and ideas. I have a set of clear tail lights that I used to have on my gen 3 camry that Im currently not using. Ive sort of grown out of the phase I was in and Im not a big fan of the all clear tails anymore, not to mention I was always nervous about their visibility and being pulled over.
My question is this: What would be the easiest way to convert these to red/clear tail lights? I had just planned on buying the red/clear tails but i figured maybe I could save some cash and make these work. Any ideas? I know about the testors candy apple red trick, I am considering that, but any other thoughts? thanks for reading.
Yeah try spraying 'em with the transparent candy apple red paint. It should work if done right. Or you could open them up and put some kind of red lens in there.
so do i just spray this paint on the outside of the lens? is it going to be prone to chipping or scratching? I do tend to powerwash my car a lot, especially to get the salt off of it in the winter. Trading is always a possibility as well, thanks for the ideas guys.
I was highly considering redding out my tail-lights with the Testors Candy Apple red spray you were talking about. But the biggest obstacle of course is opening the taillight housing. Do you guys have instructions on how to remove the housing from the car, and then opening the actual housing to spraypaint the amber part? I took a look at the housing today and it seems like you just can't spraypaint the outside cover, it wouldn't look right because the way the taillights are designed, there is a clear cover over the actual colored part (the part you want to color right?).
Help?
Help?
I wouldn't paint the outside. You would need to figure out how to open them and paint the inside. If it is sealed like a headlight, which i'm assuming it is, then you can bake them in the oven to soften the adhesive and pry them apart.
Otherwise if you just want to paint the outside check this link
it's actually easier on the outside and as long as u spray enough and clear coat it, then it should be fine (maybe touch it up every summer) but taking apart the tails is def. more difficult than the headlights!!!!! also if he has amber tails (funboy102) what good would it do spraying it on the inside???
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
Whocares04, what do you mean by since I got amber tails, it would be useless to spray the inside? Would red paint over amber cover wouldn't look right?
I think I will paint the outside cover of the amber turn signals; it the paint blends in well, I will use the whole can on the whole back panel EXCEPT the reverse lights and a 1" by 2' section where it says C A M R Y. It's so that if someone look at the back panel, there wouldn't a patch of paint only where the ambers are. What do you guys think? Is this possible? or will it look ugly?
