Interior Light Tested "No Power"!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2004, 08:58 PM   #1 (permalink)
View 94_v6_camry's Photo Gallery
Hi,
My interior light is not working on my GEN3, i did take off the 4 screw and use a test light to test for power BUT it seem to me there is no power coming through...so i am just wondering where can i look to fix the probs, i already had check all the fuses and they seem OK.
The interior light i am talking about is when you open the door the light will come on, and it can be set to "ON", "OFF" "DOOR", it's located right in the middle of the car.
Cheers
94_v6_camry is offline   Reply With Quote
Old 12-12-2004, 09:30 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
If your interior light has the slow dimming feature..it may be in that circuit somewhere...but im not sure where to locate it.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 12-12-2004, 09:39 PM   #3 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Did you guys see the 94 Camry Service and Wiring links that where recently posted ?? All the info is there including troubleshooting. There are 4 different circuits listed.
CraigW is offline   Reply With Quote
Old 12-12-2004, 09:43 PM   #4 (permalink)
The Asian Sensation
View Xevuhtess77's Photo Gallery
the light doesnt turn on at all, even if you switch the switch to on? if it's only when it's set to door, then check the little sensors on the doorframes, those get sticky a lot
Xevuhtess77 is offline   Reply With Quote
Old 12-12-2004, 10:07 PM   #5 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Are you sure the dome light fuse found under the hood is still good?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 12-13-2004, 12:24 AM   #6 (permalink)
Where exactly is that userlain?? do u have a pic?
i really need to get it fixed coz its quite annoying
Old 12-13-2004, 10:27 AM   #7 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
check fuses
Porkch0p220 is offline   Reply With Quote
Old 12-13-2004, 10:34 AM   #8 (permalink)
View Lord Anonymous's Photo Gallery
Maybe a bad contact. You can open, and move the light. I've the same problem on my gen3.
94' Camry L4, 540'000 kms (~337'000 miles)
93' Camry L4, 253'000 kms (~158'000 miles)
95' Camry V6, 240'000 kms (~150'000 miles)
Salutations from France
Lord Anonymous is offline   Reply With Quote
Old 12-13-2004, 04:44 PM   #9 (permalink)
I did open up and have a look, i use a test light to test if there is "power"!!
I did check all the fuses, want i want know is i want to know where the power of the source is, coz i already check the power to the interiors light bult...it's not coming through!!
Old 12-13-2004, 04:47 PM   #10 (permalink)
userlain's Avatar
It is in the fuse box under the hood right by the battery. On the top of it will be a diagrahm of the fuses. You want to check(and replace) the "Dome Light Fuse".
Old 12-13-2004, 04:50 PM   #11 (permalink)
Ok i located the "Dome Light" fuse check it seem O.K.
Where else should i be looking at????
Old 12-13-2004, 05:12 PM   #12 (permalink)
userlain's Avatar
Is your clock and the red "Door" dash icon working?
Fidget with the switch a little bit.
Old 12-13-2004, 05:20 PM   #13 (permalink)
What do u mean the red Door??
the clock is working fine mate!
Old 12-13-2004, 06:10 PM   #14 (permalink)
The red light that tells when the door is open. the same switch activates both the interior light and the door warning.
What is the trim level ?? Does the interior lamp have the auto dim feature. Have you done any recent wiring changes / installations ??
Old 12-13-2004, 06:24 PM   #15 (permalink)
^^^ does the trunk lamp work ?? ^^^
