Power Steering:hard to rotate - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2004, 09:59 PM   #1 (permalink)
View taimurakhter's Photo Gallery
Canada Power Steering:hard to rotate
I have found that my steering is hard compare to ACURA RL 96. I have performance tire on it.Its 215/50 R17.I drove my firend's RL and his steering is pretty loose like you can turn the steering by 1 finger.Compare to his car my Camry's steering his harder.
My steering is hard on the highway speed as well (compare to not that hard when the car is idle)
Do you think Camry's steering is manufactured different from Acura RL?You think the stiffness of the steering of my car is normal. i checkd my power steering fluid and its between max and min when the engine is hot.I have not found any leak yet.
Camry 2001.
I-4
taimurakhter is offline   Reply With Quote
Old 12-12-2004, 10:52 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
I have the exact same setup for wheels and it became heavier.
I don't mind it, actually like it. When you are blasting down some bumpy road, the heavier steering feels better.
amerikim is offline   Reply With Quote
Old 12-12-2004, 11:37 PM   #3 (permalink)
5sp 3VZ-FE
mescalito's Avatar
View mescalito's Photo Gallery
weird you think yours is too stiff when i hate my gen 3's loose feel - although it could be a larger issue
i dont know how it could be manufactured THAT differently, all use similar linkage/rack + pinion setup
mescalito is offline   Reply With Quote
Old 12-13-2004, 11:52 AM   #4 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
every car is different. I worked 5 years as a valet parker..and i've seen em all. Yes, camry's p/s in general is more stiffer (less loose) than acura RL's. THe most loose (smoothest) was the early 1990's Mitshu Pajaro (sold here as montero). Man that was like a silk cream....
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
