Help!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2004, 12:47 AM   #1 (permalink)
View tskelton1211's Photo Gallery
wires through firewall
ok i have read a number of post about running wires through the rubber grommet on the drivers side wheel well...
i have a gen 4 5sfe
everyone keeps saying to take the plastic off from the wheel well....i havent been able to go look yet but should there be some sort of plastic piece that is covering the inside of my wheel well that when i remove it i should see the gromment with the wires so i can run wires through there???
ALSO
how do i go about removing the plastic in the wheel well???
thanks
tskelton1211 is offline   Reply With Quote
Old 12-14-2004, 04:45 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Yes.
ALSO how do i go about removing the plastic in the wheel well???
1. Jack up the car.
2. Remove the front drivers side wheel.
3. Remove the fender liner. Its held on with bolts, screws, and clips.
"Skoolin' the unlearned!"
Old 12-14-2004, 08:16 AM   #3 (permalink)
Help!!!!
ok im running some wires from the engine to the inside...i have removed the plastic inside the wheel well...the wires can easily go through the grommet going from the engine INTO the wheel well...then there is a second grommet where the wires run from inside the wheel well into the car...there is NO ROOM AT ALL for me to run any wires through!!! what should i do???
thanks
Old 12-14-2004, 08:34 AM   #4 (permalink)
Gameroom cash: $147537
You should be able to feed the wire through one of the grommet which have stock wire in it. There maybe other rubber plugs you can drill a hole to feed the wire.
Old 12-14-2004, 10:15 AM   #5 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
make your own hole
Porkch0p220 is offline   Reply With Quote
Old 12-14-2004, 06:26 PM   #6 (permalink)
had to make my own hole...luckinly no drilling into the booster this time...thanks
Old 12-14-2004, 10:54 PM   #7 (permalink)
Don't drill into any wires.
