Steering Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2004, 04:36 PM   #1 (permalink)
View taimurakhter's Photo Gallery
Angry Steering Noise
I am getting noise when I turn the steering wheel. The noise is kind of rubbing or whining or goaring whatever you wanna say it
I checked the power steering fluid level and its between max and min when the engine is hot.
I fing my steering pretty stiff to turn as well. I have 17 inch rim with 215/50 tire.
Do you think the rim and the tires are causing the steering wheel stiff to turn.
Any comments or ideas about the noise????????
Camry 2001,
I-4
83000 kms
taimurakhter is offline   Reply With Quote
Old 12-14-2004, 05:33 PM   #2 (permalink)
grrroarr... ?
View jaguar's Photo Gallery
Must be your servo pump, don't know if it's fixable though
i especially get a loud noise when completely turning the steering wheel to a side; i hear some noise when just cornering.
i never tought much of it ...
94' 2.2 Camry
-fast enough to get tickets-
jaguar is offline   Reply With Quote
Old 12-14-2004, 05:43 PM   #3 (permalink)
asscarracer's Avatar
View asscarracer's Photo Gallery
I have the same problem in my camry, is it the belts?
1993 Camry LE w/ 104xxx mi
Python Remote Start/Entry, Low-Beam Silverstars, Ceramic Pads, Double Tipped Platinum Plugs
asscarracer is offline   Reply With Quote
Old 12-14-2004, 06:09 PM   #4 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I got the same problem. I think Mayber it's the pump.
http://www.xclusive.bz
Old 12-14-2004, 07:04 PM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
There's a TSB ST002-03 dated june 13 2003 for 4 and 6 cylinder Camries describing a low frequency noise when the steering wheel is turned at low speeds due to friction between the intermediate shaft and grommet.
The fix is to lube between the shaft and the grommet. The recommended grease is Seal-Tite Dielectric grease or equivalent
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-14-2004, 09:06 PM   #6 (permalink)
Speed Racer
toyotachick's Avatar
View toyotachick's Photo Gallery
I had the same thing with my 4 cyl. It was the power steering belt. The sound sounded like a loud squeeking noise. Hope thats what it was, simple to fix
I would rather be hated for someone I am, then to be loved for someone I am not.
toyotachick is offline   Reply With Quote
Old 12-15-2004, 04:36 AM   #7 (permalink)
grrroarr... ?
yeah, i'm bound to change my acc. belts some time soon, maybe it'll fix it
if not i might try to lube it; but it just isn't a priority in my book...
should it be? does the noise indicate wear ?
94' 2.2 Camry
Old 12-15-2004, 09:01 AM   #8 (permalink)
View 99CamV6's Photo Gallery
I have this problem too, when i do the turning especially right turn, i hear a loud squeeking noise come from my right front wheel. Is it the same problem as his?
99CamV6 is offline   Reply With Quote
Old 04-04-2005, 08:18 PM   #9 (permalink)
Was it the power steering belt? Was it fixed by replacing the belt?
