need engine help!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2004, 08:01 PM   #1 (permalink)
View lostpaki2003's Photo Gallery
Unhappy need engine help!!!!
I need to know if the 97-01 4cyl engine will fit in a 94 camry. Or a engine that I could swap into the camry body keeping the auto transmission.
lostpaki2003 is offline   Reply With Quote
Old 12-15-2004, 11:24 PM   #2 (permalink)
engineer in training
Gameroom cash: $145055
yes the 97-01 4 cyl (5S-FE) will fit into a 94, should be a drop in swap
Old 12-16-2004, 08:08 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The engine will bolt up, but you have to change stuff over.
97 - 01 5S-FE have DIS (distributorless ignition system) and a returnless fuel system.
What this means is that you need to change the wiring harness, ecu, and redo the fuel system.
You'd be better off finding an engine from a 94 Camry.
"Skoolin' the unlearned!"
Old 12-16-2004, 08:29 AM   #4 (permalink)
Gameroom cash: $147537
DIS and returnless fuel system on 5S-FE!!!
Does it get more HP and Torque?
So that's even better then 92-99 Celica 5S-FE (135HP, 145lb-ft)?
Old 12-16-2004, 02:44 PM   #5 (permalink)
thanks.
Old 12-16-2004, 04:13 PM   #6 (permalink)
View Nico's Photo Gallery
DIS was on 5sfe since 1994. (1992-93 were with a distributor). But I don't know about that fuel return thing. I agree with 88le, you d'better go for an engine of your car's year (from 1994 up to 1996 and you can be sure to be alright).
Nico
Nico is offline   Reply With Quote
