Flasing O/D Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2004, 08:30 PM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Flasing O/D Light
Sometimes...my O/D indicator light on the dashboard flashes (about 1 per 1.5 to 2 seconds) when i'm in Overdrive. When overdrive is off, it's stays on as normal..
What does this flashing mean?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 12-15-2004, 08:34 PM   #2 (permalink)
View JohnCWms27's Photo Gallery
do u have the stock shift knob? it sounds like a bad connection the wire somewhere...possibly where it connects to the button on the shift knob
'94 Camry LE
JohnCWms27 is offline   Reply With Quote
Old 12-15-2004, 08:38 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
The O/D light flashes to inform you that the ECU has stored one, or multiple trouble codes.
Might wanna check that out...
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 12-15-2004, 08:40 PM   #4 (permalink)
VeeZed
Definetly not a loose connection...it flashes too consistant.
Trouble codes! Interesting. Thats a very good piece of info...I tell ya...Toyota weren't stupid when they designed these cars!!
Thanks Toysrme.
Old 12-15-2004, 08:47 PM   #5 (permalink)
Toysrme's Avatar
Cool
n/p, if it's like 3vz-fe (should be) just bridgeTE1 and E1 in the diagnostic port in the bay.
Turn the key to ON and it'll spit out the codes with the O/D light.
All stuff you know by now
Now with Turbo!
Old 12-15-2004, 08:50 PM   #6 (permalink)
VeeZed
Turn the key to ON and it'll spit out the codes with the O/D light. {snip}
You mean spit out the codes via the CEL light...?
Old 12-15-2004, 09:05 PM   #7 (permalink)
Toysrme's Avatar
Cool
Yep, it'll flash the codes at you when the ECU is in diagnostic mode (terminals shorted) and the ignition is turned to ON. (wether or not the car is running)
Now with Turbo!
Old 12-16-2004, 01:55 AM   #8 (permalink)
View 94_v6_camry's Photo Gallery
Toysrme i did BRIDGE TE1 & E1 the "engine light" keep flashing...i was told this work normal and if i press the O/D button the "O/D light" start to flash as well.So just wonderting is that normal???
BTW i am thing of changing my lower radiator hose...and just wondering can i take it off from the top?? it look pretty tight to work on..let me know ASAP ok, thinking of doing it tomorrow!
Cheers
94_v6_camry is offline   Reply With Quote
Old 12-16-2004, 08:38 AM   #9 (permalink)
Gameroom cash: $147537
Something is wrong with the tranny. Lose wire, stuck valve. First check for oil leak around the tranny. Engine oil leaking onto tranny is not good. I had a leak from disy and its pouring oil on the speed sensor and govenor. Mine won't shift down sometime It works fine after I clean the oil off. I might need to change the seal on speed sensor and governor too.
Old 12-16-2004, 11:42 AM   #10 (permalink)
OlDsChOoLeR
View FRITO's Photo Gallery
my light did some wierd shit about a year ago, it turned out to be a faulty electric solenoid on my tranny(automatic), messed up my shifting and stuff, the cam felt slow. dont know if this could be the problem, hope it helps.
gl,
Luke
FRITO is offline   Reply With Quote
Old 12-16-2004, 03:56 PM   #11 (permalink)
Well from the external view i can see my car is leaking A/T fluid under the A/T. It's only a bit a fluid and its not all the time, is there a guide on how to test if the electrical is working ok??? i got a 3VZ-FE engine GEN3
Old 12-28-2004, 03:06 AM   #12 (permalink)
VeeZed
Australia OD Flashing AGAIN!
The O/D Light is now blinking AGAIN. I checked the CEL by shorting TE1 and E1 of the DIAG connector and there is NO error codes present in the computer.
Judging by the flashes of the O/D light, it reads either 16 or 61. Six flashes followed by a pause then a single flash followed by another pause, or vise verca.
Does anyone know what this means?
(So much for the error code has been stored idea!!)
Thanks.
Old 12-28-2004, 10:03 AM   #13 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
6 flashes, then pause, then 1 flash isnt a code in my book, but the book says its for the CEL, maybe since its the O/D light flashing, its a trouble code for the transmission, the tranny has a seperate computer.
i dont know where you can get the code info for the tranny
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 12-28-2004, 10:32 AM   #14 (permalink)
Bring it !
View WickedGen3's Photo Gallery
well i had some problem with that in my 92 camry 4 cyl. it happened after i changed the tranny fluid and filter and it started blinkin when i hit overdrive on the highway. series of blinks so i called my mechanic and he said that there could be something wrong with my tranny.. thought it was doomed so i got crazy one day and this is waht i did
unplug the ecu fuse under the coin holder by the left of the steering wheel and crank the car couple of times and then put back the ecu fuse and now it runs fine no blinks i told my mechanic what i did and he said that sometimes is the ecu thats messed up so you could give it a try but be careful .. i did it b/c i hated the dam thing always flashing
hope this helps
WickedGen3 is offline   Reply With Quote
Old 12-28-2004, 11:01 AM   #15 (permalink)
Post Hoc Ergo Propter Hoc
Bishop13's Avatar
View Bishop13's Photo Gallery
Thanks.
Actually, you have to read the flashes on the O/D light, not the CEL. The transmission has its own diagnostic system and is not connected to the CEL. Anyone here have a Haynes manual handy for the trouble codes?
Capitalization is the difference between helping your uncle Jack off a horse, and helping your uncle jack off a horse
1997 Toyota Camry LE / 2001 Land Rover Discovery II / 2006 Audi A4
http://www.flickr.com/photos/henryenriquez/
Bishop13 is offline   Reply With Quote
