How long do Tokico struts last? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2004, 01:40 PM   #1 (permalink)
metamorphosis
cman2000's Avatar
View cman2000's Photo Gallery
I have tokico struts with eibach springs for about 40,000 miles now. (got them when my car is about 55K miles, now it's at 92,000 miles). I know i drive alot - alot of out of state places.
anyways, when i go over bumps recently, I noticed a "clicking" sound coming from my right rear tire area. it sounds like the springs, or more likely struts, are squeaking or adjusting themselves? never really had this problem before so not sure what it might be.
Also, the problem started AFTER i had my tires rotated...you'd think it had something to do w/ that?
you'd think it's my struts? or maybe I need to balance my tires (i didn't after rotating tires?)
any other suggestions of what it might be? thanks
2005 Acura RSX Nighthawk Black Auto w/ Black Leather
2000 Camry LE - Damaged in a wreck (other driver's stupidity ) . being repairing as we speak...
cman2000 is offline   Reply With Quote
Old 12-16-2004, 01:50 PM   #2 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
when you originally got them, you also got a sleeve incase they ever wear out, they have lifetime warranty, provided you bought them and it didn't come with the car u bougth!
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 12-16-2004, 02:01 PM   #3 (permalink)
The Smashing Pumpkins
rapsux2000's Avatar
View rapsux2000's Photo Gallery
Sounds like it could be your strut mounts. I had a different experience though. I had the same problem as you, but it turns out that the thin bar that's kinda like a little arm that folds and connects to the top of the strut was lose. This little arm has a threaded bolt attatched to it, and slides into a tiny hole at the towards the top of the strut right behind the tire. Check to see if that nut is tight. In my case, the nut ultimately fell off and the bar flapped around. So I had to get a new nut and make sure it was very secure. Good luck.
Click on the link below this sig for info and pics of my 99 Camry.
http://www.toyotanation.com/forum/t44068.html
Sohil
rapsux2000 is offline   Reply With Quote
Old 12-17-2004, 12:28 AM   #4 (permalink)
metamorphosis
cman2000's Avatar
^^ thanks for the advice. i'll go check it out tomorrow.
